Old 01-28-2003, 04:19 PM
phoenixsvx
? about valve gaskets
I am going to have both valve cover gaskets replaced and my mechanic is saying parts are going to run around $525, that is for gaskets and spark plugs. Because i have not had it done before i don't know if that is high or about right. If it seems a little high can anyone suggest somewhere to get parts cheaper.
As for my previous rev up prob, it was a combo for PVC valve and my overdrive sensor was malfuntioning. All better now. that to eveyone on your inut :
It was cold in Phoenix today about 80
Old 01-28-2003, 05:00 PM
Parts should be about $50 for the valve cover gaskets, and about $65 for the spark plugs.
Definitely not $525, unless he was quoting the labor too.
Call Liberty Subaru at 201-261-0900 and tell them you're an internet customer to get better rates.
Old 01-28-2003, 05:01 PM
cbx-man cbx-man is offline
check out www.subaruparts.com
http://www.subaruparts.com/diag/?mod...category=020-A
all 6 gaskets = $56
8 rubberseals = $16
6 spark plugs= $57 (6 x $9.53)
$525 for labor would be about right, but not parts.
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 01-28-2003, 06:06 PM
kuoh kuoh is offline
Man I'm going to have to start my own business doing just spark plugs and valve cover gaskets! I could make a killing even if I only charged half that labor rate.
KuoH
Old 01-29-2003, 06:22 PM
phoenixsvx
Thanks now i know they are crazy,525 was parts, now i have seen other site for parts, would it be smarter to get an entire gasket set, Oh yeh front seal will need to be done also, Labor on that is $900, entire sets are around $266 one from part.com and one on subaruparts.com
Old 01-29-2003, 07:46 PM
gcookaustin
I had the valve cover gaskets, spark plugs, timing and acc. belts, and front seals replaced all for ~$1050 at the not-so-local Subaru dealer. If that's any help
