Old 01-12-2003, 02:12 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Caliper torque specs
I finally have a question to which I couldn't find the answer on the forum so here goes.
I'll be doing a brake job on the fronts shortly, because yes, they are warped again!! I was wondering if anyone had the torque specs for the caliper and hanger bolts.
I was thinking of getting the Race Concepts rotors and I read some good things. Anyone have long-term opinions about these?
Thanks.
Old 01-12-2003, 06:20 PM
mbtoloczko's Avatar
sans SVX
Aren't the torque specs in your service manual? As for the rotors, there was a thread a while back where people are claiming that cross-drilled rotors will eventually crack. Might want to stick to just slotting the rotors. What pads are you using?
Mychailo
Visit my locker
Old 01-12-2003, 06:34 PM
lee lee is offline
Re: Caliper torque specs
Originally posted by SVXer95
...snip...I was wondering if anyone had the torque specs for the caliper and hanger bolts....snip
here ya go.
Old 01-12-2003, 08:16 PM
Word to Yo Motha
Thanks for the numbers.
As for the rotors I was pretty sure that the Race Concept rotors were not cross drilled yet dimple drilled to min thickness. I was thinking about going for the EBC greenstuff pads. I have always used AE organic pads from NAPA but these look about the same price.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 01-12-2003, 08:40 PM
lee lee is offline
do a search on green stuff, something about having to order the SUV pads from a Nissan. As an alternative to OEM and EBC, I'm thinking about akebono ceramic pads next time. The site below shows them for the SVX at around $50 per axle.
https://www.olyonline.com/akebono.htm
Old 01-13-2003, 12:14 AM
mbtoloczko's Avatar
sans SVX
Re: Re: Caliper torque specs
Originally posted by lee
here ya go.
Those numbers do not match what's in my Chilton's manual. It lists the knuckle-to-caliper support bolts as 68-88 ft-lbs and the support-to-caliper bolts at 34-44 ft-lbs.
Mychailo
Visit my locker
Old 01-13-2003, 08:56 PM
lee lee is offline
Re: Re: Re: Caliper torque specs
Mine came from Alldata - obviously we need somebody with the factory manual to chime in here, I don't have a copy.
