Old 01-16-2018, 01:40 PM
Cotton's Avatar
Cotton Cotton is offline
Some Random Weirdo
Re: Bontrager Works 22mm rear anti-sway bar kits (1/15/18)
Originally Posted by Nevin View Post
Unless you have changed your hubs, there should be no reason to have any different parts, this Will still be a direct bolt-on affair.
And as to the intake pricing, not sure on that yet either... my guess would be in the similar $300-$325 range, depending on options. Options will most likely be whether or not additional pipe is included to put the filter in the fender for a CAI setup, and then the filter itaelf, as most people already have some sort of maf adapter pipe and are already running a cone filter of some sort. I would imagine the base version would be in the $200- $225 range??
Again, I will start another thread for that.
I am interested in the intake for sure.
94 SVX LSI- Rebuilt engine, 4.44 with trans cooler, Quick Change Shift Kit, SS exhaust with Magnaflow muffler, 08 STI Wheels, K&N Filter, and still adding.
Old 01-16-2018, 01:48 PM
Nevin's Avatar
Nevin Nevin is offline
Originally Posted by GC 2 NV View Post
Oh, is it just the front that the sway connects to the strut then?
Correct, the rear swaybar endlinks connect to the hub itself, not on the struts like the front bar. This is a MUCH sturdier design, thankfully.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 01-16-2018, 03:20 PM
svxnavyvet svxnavyvet is offline
I'm in for a sway bar kit.
Plus I like this forum better then face book you can do search and read in a list form a lot better.
Also will the y pipe work as good as going two intake pipes and mafs I'm putting two hood scope on my glass hood was going two mafs and forced air Lane makes a chip for two.
Thanks
Jim
Old 01-16-2018, 03:35 PM
Nevin's Avatar
Thanks
Jim
Cool! Well ive been out of the game for so long that I have no idea what forced air Lane is! Although I would love to know!
I have an ecutune 1v5 chip in my car.
Jesus is the remedy
Old 01-16-2018, 04:56 PM
not all together its just lan (aka long ass name)he has been making chips and blowers, trans, here on the svx net for ever his known also a subiechips on the web
http://www.subiechips.com/index.htm
looking forward to a sway bar.
Old 01-16-2018, 07:52 PM
Nevin's Avatar
Ok, then yes I am familiar with LAN. (Mike??) He has sent me a few parts over the years and I have been quite happy with them!
Jesus is the remedy
Old 01-17-2018, 11:00 AM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
Will you be making any extra? Ive been dreaming of having both the intake and RSB but im a a little tight on money....atleast until tax return comes in.
1992 SVX LS
2002 Park Avenue
2008 328i convertible
1993 GMC C1500 W/T
Old 01-17-2018, 08:36 PM
Nevin,
Can you offer any further updates on the new endlinks you have. Those who still have your original RSB might want to upgrade from the ones you first offered.
I think your new ones are a bit shorter and not as prone to rattling and loosening with age.
I replaced my noisty originals with QS Chromoly Teflon Kevlar ones, but they too become noisy. Was going to add end link boots to them filled with grease.
Are you still using the MOOG K90520?
Any info would be of interest,
John
Old 01-17-2018, 09:05 PM
Nevin's Avatar
John, I am no longer using the QS components pieces.
I am using a similar offering from another company. I can easily get you the newer ones and they are a similar design and will eventually also start to rattle but they will last much longer. I can easily sell someone new links every few years for a few dollars and we can call it a wear item, but these were not designed for comfort in mind, so i havent been looking for another style becaise I don't want to give up performance at all.
Pm me if you have questions.
Jesus is the remedy
Old 01-18-2018, 03:49 PM
Nevin's Avatar
Posted up the bars in the Group Buy section today!
Here is the link.
http://www.subaru-svx.net/forum/show...990#post747990
Happy Driving!
Jesus is the remedy
Old 01-24-2018, 09:48 AM
immortal_suby's Avatar
Thread Killah
I'm still runnning the original set of endlinks from when I got in on your first run of sway bars. They are noisy but as long as they aren't going to fail I just turn the radio up. At 306k there are so many creaks and rattles in the car it doesn't even bother me. I still love how flat the car corners compared to stock. I would never go back to a smaller sway bar. Thank you for making my svx so much better!
Locker Link
2015 BRZ Limited 6MT
Old 01-24-2018, 10:22 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
I'm part of the previous buy and my endlinks are just starting to rattle, after about 20,000 miles of daily driving plus track and autocross days. Pm info on the new ones you are going to use.
Thank you,
Sam
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 07-21-2018, 12:35 PM
Jvan Jvan is offline
I wanted to be part of this purchase but my car was involved in a major front end accident and I'm still trying to put it back on the road. But I have a question about just upgrading the rear sway bar; how does this affect driving? My understanding is that increasing the rear sway bar will increase either over steer or under steer (don't remember which). I'd like to decrease body sway while turning but without increasing either over/under steer.
Old 08-05-2018, 06:20 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
Rear sway bar should work to reduce sway and will reduce the factory understeer
[SIGPIC][/SIGPIC]
