Old 01-29-2015, 04:47 PM
Huskymaniac's Avatar
Uses the ignore feature
Acura forum is not so good...need help
The clutch on my Acura TL is acting wonky. The baffling part is that it is intermittent. Sometimes the clutch will grab at a much lower pedal position than normal. Usually when it does this it also sticks or returns very slowly. On some mornings the clutch will not fully disengage when I press it to start the car. If I press the pedal, put it in neutral, release the pedal and press it again, the car starts fine and I can easily put it into reverse.
It is a 2005 TL with 136K miles on it. The first thing I tried was to replace the master cylinder. It worked fine for a few days and then the problem returned. It seemed to return gradually. I had my mechanic do the MC because it was noisy and I was going to replace it anyways. And the itermittent nature of the problem made me suspect the hydraulics. I don't know if he flushed the system with new fluid or just bled it.
Any suggestions?
Tony
Old 01-30-2015, 10:40 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: Acura forum is not so good...need help
Maybe replace the clutch slave as well and check the clutch hose?
My SVX does this as well, but I think it's from the 200k+ mile used Outback clutch MC I used in my swap.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 01-30-2015, 12:03 PM
i would replace the slave and the rubber line that goes to it then flush it with dot5 brake fluid. i had a similar issue on a civic and the inside of the hose was coming apart and would intermittently block flow. when flow was blocked it blew out the seals in the master and slave.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 01-31-2015, 05:15 AM
wdb wdb is offline
dances with roads
I agree on fully checking out the hydraulics. It's easier and cheaper than cracking open the car to get at the clutch.
But it could also be the clutch disc binding on the transmission input shaft. It should be able to slide freely but if it binds it could cause erratic engagement and disengagement issues as you describe.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
