Old 01-03-2015, 02:57 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Air-Con controller repairs (1 of 2)
Since all work has been done around house - and real work starts tomorrow, I decided to fix as many of the controlllers as possible... only took me 2 hours to fix 4 of them, the rest are toast due to plugging/unplugging while ignition was turned on (no diode protection on micro pins).
Now there should be a couple of people in NZ with cool air for summer...
I must thank Shane for cutting the connector wires from his old wrecked SVX - I managed to make up a test system outside of the car..... just waiting to confirm that all is right within a car - so waiting for Shane to arrive in Auckland in order that we plug each one in.
Old 01-03-2015, 02:59 PM
SURTEESS's Avatar
Air-Con controller repairs (2 of 2)
some more pictures only..............
