Old 07-03-2014, 05:14 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Subaru Recall
Sorry to see Subaru getting caught up in the PR recall nightmare. Rusting fuel lines? Is this really something new? Hope none of you are part of this or, at least, Subaru will handle it better that GM and Chrysler.
Gene and Ben
Old 07-03-2014, 06:41 PM
theflystyle's Avatar
Re: Subaru Recall
That recall has been out for a little while now. My Legacy was in the range of models hit but I havent taken it in. If your lines are not rusted they just put some rust prevention material on the lines. If they are bad then they replace them.
Link the recall on the Legacygt.com forum
1994 SVX LSi
2008 Legacy 3.0R
Old 07-03-2014, 07:10 PM
Re: Subaru Recall
All brake lines and fuel lines should be made of stainless steel. It's a safety issue.
I'm sick of replacing them on every vehicle I own.
Old 07-04-2014, 05:38 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: Subaru Recall
100% agree. Can't cost all that much if done on every car on all platforms during production.
Old 07-04-2014, 05:40 AM
gwynethh's Avatar
Re: Subaru Recall
"If your lines are not rusted they just put some rust prevention material on the lines."
Sounds like a band-aid fix that will need to be watched forever.
Old 07-06-2014, 11:44 AM
Re: Subaru Recall
You mean like all Subaru "recalls"?
Old 07-06-2014, 11:46 AM
Re: Subaru Recall
I agree. The extra cost can't be that much more. After dealing with Subarus so much, about a year and a half ago I went and inspected my hardlines closely on the audi. 250k miles in the Lake Erie snow belts can't be good along with all of the sand, gravel and mud when offroading and the water. I was shocked to see them still clean as could be. 15 years later. If it were a Subaru, they'd have been replaced at least once and be needing it again. European cars are a no brainer for me with the climate up here. It's sad really.
Old 07-09-2014, 05:16 PM
Re: Subaru Recall
http://www.forbes.com/sites/jimgorze...-recall-rates/
interesting reading about recalls. have to click past the advertisement to read.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 07-19-2014, 09:50 AM
bwb3's Avatar
Re: Subaru Recall
More Subaru problems?
(AP) — Some Subaru vehicle models have a defect that could lead to engine failure while they're being driven, a federal lawsuit says.
The lawsuit alleges violations of the state's consumer fraud act, breach of express warranty and other violations. It says piston rings in the vehicles wear out quickly and some vehicles burn excessive amounts of oil.
The models affected by the defect are the 2011-14 Forester 2.5-liter, 2013 Legacy 2.5-liter, 2013 Outback 2.5-liter, 2012-13 Impreza 2-liter and 2013 XV Crosstek 2-liter, according to the lawsuit.
The oil consumption issue "can cause engine failure while the Class Vehicles are in operation at any time and under any driving condition or speed," the lawsuit says. "This exposes the driver and occupants of the Class Vehicles, as well as others who share the road with them, to an increased risk of accident, injury, or death."
Gene and Ben
Old 07-20-2014, 10:03 AM
Re: Subaru Recall
Have a friend who brought his legacy to me two weeks ago because he had surging and variable cam timing codes. Found about 1/2 quart of oil in the pan so I changed the oil. Came back this week for check up, same amount of oil in pan. Burned 4 quarts in two weeks. No leaks, no smoke. Never seen anything like it, it just disappears.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 07-24-2014, 02:40 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Subaru Recall
Hard to believe. If the Legacy isn't a fogger while it's being driven, then it must be leaking like a sieve. Did you have the car up on a lift to do the oil change?
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-25-2014, 08:29 AM
Re: Subaru Recall
Had it on lift twice. I think it must only burn oil under load at higher rpm when the smoke would be pretty diluted. Ran it on the lift and didn't drip once.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 07-25-2014, 05:58 PM
bwb3's Avatar
Re: Subaru Recall
Because of the lawsuit, this must have happened to other owners. As one who was interested in purchasing a late model used one, it causes me some concern.
Gene and Ben
