front top hat
Could someone post me these dimensions of front top hat. I am planning to do front camber plates for my svx.
I would measure them myself, but my car is 200km away from me. edit:these top hats in the picture are not from the svx, just for clarification.
svx my94 vtd EUDM -custom Spax coilovers Last edited by Chris_; 01-08-2013 at 05:00 AM. |
Re: front top hat
I believe I have that information. I'll dig around when I get home from work.
Re: front top hat
I threw a quick drawing together. Unfortunately I only have dimensions 1, 2 and 3. When I took them a while back I didn't consider the center distance. I believe they form a concentric circle to the center bolt of the strut though, so dimensions 4-6 should be equal.
The dimensions should be pretty close, they worked for me when I changed my suspension with STi stuff.
Re: front top hat
Dimensions between the bolts seems to be higher than I expected, but if you go with those then I believe you Thank you for the help.
svx my94 vtd EUDM -custom Spax coilovers |
Re: front top hat
They are much larger than any other Subaru top hat if those were numbers you were looking at.
Thread Tools | |
Display Modes | |
