Old 09-30-2011, 05:26 PM
Rod.'s Avatar
Rod. Rod. is offline
My '97 has my '92's engine and she's running!
Got the call from my mechanic that she's done and runs well. I'll pick her up tonight.
The '92 hadn't run in 5 years so it was a bit of a crap shoot, but after it got stripped down and the good bits were swapped in from the '97, and new head and bottom gasket sets, timing belt, water pump, & thermostat, she's done.
Can't wait to bring her home!
Rod.
'97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD
'92 Ebony LS-L #6851, USDM (sold)
'08 Forester (wife's)
'06 STi (traded for the Forester)
'94 Legacy wagon (sold)
Old 09-30-2011, 06:19 PM
Re: My '97 has my '92's engine and she's running!
Wow that is quit a swap 1st to Last . A lot of info in the ECU had to be changed Right?
Old 10-01-2011, 12:49 AM
Nope, other than the EGR stuff swapped over from the intake manifold, everything is mechanically 100% the same, and the ECU will be fine. The 3rd O2 sensor is on the body harness, so that's not an issue. The OBD2 EGR is actually quite different from the earlier cars. EG33s are all pretty much the same. (As I just learned) the water pump is different on some of the Euro cars, and the Japanese cars didn't have any EGR stuff at all. All the essential sensors, and mechanicals and stuff are the same.
Old 10-01-2011, 07:21 AM
Rod.'s Avatar
What he said...
All I know is that it works! Got her home last night after a short run. It was great to have her back and running well. It's still throwing a CEL that I suspect is the 3rd O2 sensor but I haven't pulled the code yet.
Rod.
Old 10-01-2011, 09:12 AM
I applaud you sir. Great job ...another one saved.
Old 10-01-2011, 02:13 PM
Good job Rod! This seems to be the week for bringing stricken SVXii back to life.
