Old 09-13-2011, 07:59 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
The Power Mode Mod, finally.
Finally did it, after owning my SVX for 3 years and it's awesome. I was always worried with other issues regarding the car to ever really mess with any performance mods of any sort, until now.
I was motivated last night and looking at how really easy it was, tracked own the items in my house to ground it.
Having an exhaust leak right around the cat. the check engine light would always come on after about 5 minutes of driving anywhere near of 40mph. With the power mode on the entire time, the check engine never came on the 40 minutes I drove it today. At all. The CEL is for the O2 sensors, IIRC.
That, and my windows work again. Haha... so now I'm wondering if the short in the window wire under the seat has any relation at all to the CEL code thrown for the o2 sensor (most likely not, right?) or if the power mode just disregards the o2 sensors to some extent? It really does make me wonder why USDM did not get the sport mode button... unless it is somehow related to passing emissions, I'm unsure how the JDM does it, emissions that is.
1994 subaru svx le 112k
Old 09-13-2011, 08:43 PM
wohnson89's Avatar
wohnson89 wohnson89 is offline
At home in the flatland
Re: The Power Mode Mod, finally.
Is there a page in the "how-to-documents" on how to do this? If its that easy, I might try it now.
1992 Subaru SVX LS-L Pearlie
1989 Mazda RX7
2005 Mini Cooper S
Old 09-13-2011, 09:37 PM
Subix's Avatar
Not sure about how-to but there's a thread about it:
http://www.subaru-svx.net/forum/show...power+mode+mod
I made a video of how to do it on youtube but can't access it at work right now. It's like 2 mins long but shows you how easy it is.
Old 09-14-2011, 09:26 AM
Read that thread and if you still have questions you can ask. It's pretty easy and a lot of us have done it.
Old 09-14-2011, 06:18 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
should i disconnect the car battery before doing this or does it not matter?
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 09-14-2011, 06:36 PM
Absolutely. Anytime you are dealing with the computers.
Old 09-14-2011, 06:39 PM
Subix's Avatar
Good idea, the thought had came to mind but I didn't really see it as cutting into any wires as it is just grounding one as a switch. I did pull the harness/connector out and insert my pin first then insert the connector and then grounded the wire.
Old 09-14-2011, 11:00 PM
B 4 You's Avatar
#lolsvx
i thought so... just making sure. now i think i'll attempt this mod this weekend. :] i want to switch pin 4 to pin 6 so i can just use the manual button to try it out. how hard is it to pull out the wire? i REALLY don't want to break anything..
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 09-14-2011, 11:22 PM
Subix's Avatar
I think you would have a harder time trying to remove that pin and put it in A4 than if you just put in a connector and grounded it. Just my opinion though.... it's a weird angle and looking up for more than 5 minutes makes me nauseous.
Old 09-15-2011, 01:03 AM
Subix's Avatar
http://youtu.be/bOeMhfqHJvA
