Old 06-09-2011, 01:54 AM
decline decline is offline
mash the throttle to get it to start
any time I try to start my svx after its been sitting (ie in the morning, or after work) the only way to start it is to floor the gas while it cranks and feather it. Usually after about 30- a minute of this it will fire. It then smells like gas, and the idle immediatly goes to 800-1000 not the 13-1400 "warm up" revs
the check engine light will come on at this point. sometimes it goes away after i drive. sometimes not.
If I make any stops, the /next time it will start right up. and again sometimes CEL that maybe goes away.
I had a infrequent phantom CEL before this that would sometimes just flash for a second or two but never gave any problems
The guy at the shop checked the fuel pump said the volts look good(?), replaced a temp sensor.I replaced the spark plugs 2 moths ago, new battery, and a bunch of other stuff
He thinks its a leaky injector which floods the chamber after it sits for a while.
the other snafu is that he doesnt have the connector to read the ecu so hes not 100% i should spend $500-$800 on injectors
what do you guys think?
Old 06-09-2011, 02:09 AM
Re: mash the throttle to get it to start
also forgot to my mechanic swaped a MAF in and it didnt seem to help
Old 06-09-2011, 02:26 AM
Have you bothered checking the codes? It's a very simple process listed in the how-to's.
Which temp sensor did you change? The one wire or 2 wire coolant temp sensor? This is sounding very similar to coolant temp sensor issues.
Old 06-09-2011, 06:07 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
This was my first thought, as I went through a similar scenario.
Old 06-09-2011, 11:07 AM
talked to my mechanic this morning. He did replaced the coolant temp sensor. he was finally able to read the codes an it was for the coolant temp, which was replaced with a new oem.
problem still persist so hes gonna test/check th ecu.
Question: If the ECU is "bad" what are my options?
if it is the ecu and I chip it would that possibly fix the problem? as opposed to replacing it?
thanks in advance SVX gurus
Old 06-09-2011, 12:31 PM
There's 2 sensors. One for the ECU and one for the dash gauge. Did he change the right one? Is the code still there?
Old 06-09-2011, 02:37 PM
gbianchi gbianchi is offline
Sound like a very possible problem, also the smell of fuel points to that, but never had that problem myself, good luck..................G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 06-09-2011, 04:48 PM
1234567890
Old 06-09-2011, 06:25 PM
LetItSnow's Avatar
^^ I'm thinking what he's thinking.
Old 06-09-2011, 07:07 PM
I personally never got around to checking the codes. I'm aware its pretty easy, but counting blinking lights is apparently too much work for me.
My mechanic did replace the ECU temp gauge. Maybe its the wires, as the car sat for years before I got it.
