Old 01-22-2015, 08:22 AM
gearheadE30 gearheadE30 is offline
Re: rear sway bar project
Definitely interested in seeing the results. After autocrossing mine for the first time, it really drives like a FWD car and will rotate with trail braking, but otherwise it understeers rather badly. That bar should hopefully help out a lot.
Old 02-01-2015, 12:16 AM
Tapani Tapani is offline
It's snowing !!
So far app 5".... It's 0 degrees C, so it's good for making a snowman. I had to go for a drive.
The car drives flat and the new sway bar complements the rear bias of the VTD really nicely. Just more throttle and the rear swings around real easy. Long sweeping four wheel slides can be induced with gas only.
From a stand still too, first turn the wheel half a turn and then hit the throttle - you're immediately doing full circles - not a hint of under steer.
Lift off in manual second does not increase the slide - just straightens the car.
First impressions are very nice - should go on an ice track for more. All this depends on many things - the traction conditions are rather easy today.
So far I am really pleased.
/T
