Old 03-27-2011, 08:12 PM
Cam Cam is offline
Re: cfm to hp conversion
All this math is reflecting an engine with 10:1 CR, right? You would need a lot more if you adjusted the CR properly for a turbo.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-27-2011, 08:30 PM
radarwhiz's Avatar
Fairmont State University
These are theoretic formulas defining parameters for a target HP based on the airflow (CFM) required for that HP through any displacement engine. Just playing with the numbers to help me understand it better. Compression was not factored.
With our IRIS we can achieve over 100% VE!
Our average intake manifold temperature is 200°f!
130 was the temp their example used, I guess assuming that even the charged air could be cooled that much with an intercooler.
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 03-27-2011, 09:11 PM
Water to air intercoolers are the most efficient.
A water to air intercooler system will have a
1)radiator to dissapate the charged air heat, a
2)water to air intercooler,
(a radiator, with a sealed air passage going through the heat exchanging fins)
3)a pump to cause the weater to flow through the system.
The lowest temperature that you can hope for with this system is whatever ambiant temperature is.
This temperature can be lowered with either a gas (CO2, nitrous, whatever)
or physical element,(ice, cold water, etc.)
