Taillight, plug & play?
Four months after winning a taillight on ebay it arrived yesterday. Will this thing just plug right in or do I need to modify the wiring? It's too cold and dark for me to look.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
Re: Taillight, plug & play?
The bulb housings from your old one should just twist right in, or if it came with the harness included, plug right in.
It came with the harness. When the brake is depressed the backup lights won't come on? right.
Four months? Crap. I coulda' had you one in four days.
What was the reason they gave for a delay? |
Cost of shipping. It is cheaper to use a container once a year.
thats a rear fog rear bar... It is totally different than the US one
Tom |
Oops didnt notice the distance between the eyeballs.
Pictures, please when you have it installed. I really like the look of the rear fogs! You will need to do some additional wiring most likely, in order to utilize them. At the least, you should try to obtain the OEM switch for the rear fogs which is in the black switch cluster on the right side of the instrument cluster.
1991 SVX L JDM |
looks like my old one (which got broken by ??? another story) - if it is then the area inboard of the white reversing lights are just reflectors (no wiring or bulbs) - which country did you get it from ???
Got a new one from USA - reflector & reversing area swapped - also now the reflector in USA is another stop light....it was plug & play for me. This has all been discussed before - search for rear light variations. see my recent posting for "rear side markers" in NZ they are just reflectors - but the ones from USA that I recently purchased have bulbs fitted, still looking for the mating connector & little piece of wiring so that I can splice it into the existing loom. Steve in New Zealand Last edited by SURTEESS; 02-18-2010 at 09:55 AM. |
Surteess, the light is from a German model. The two lights inward from the clear backup lights are I believe fog lamps like Mike621 said. I'm not sure about hooking up the fogs yet. I prefer the look of having the backup lights further apart, the old girl doesn't get into much fog I may just use them opposite US OEM.
I had one of these on my previous svx. You will need to wire in the fog lights. I ran them off of my front fog lights so they would come on with them. Everything else will operate properly.
Mike
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
Finally got it in today, the rings around the fog lamps look really nice. I just have to charge my battery to see if they work. Really busy lately.
People must really be puzzled when they see your svx for the first time, think it's something new, then see classic car plates.
I did a few changes to mine,my UK car comes with two rear red fog lights(fitted with 21w bulbs) I removed these bulbs,replaced them with 5w bulbs,rewired them into the side light circuit,then I fitted a red 21w bulb into the offside reversing light housing,and rewired that back into the original fog light circuit.(you with me?) so I now have 4 rear red side lights,2 red brake lights,one white reversing light and one red rear fog light Also I purchased (thanks Nate) 2 rear/side side marker lights/lenses,fitted these with 5w bulbs and wired thse into the side light circuit.Led number plate bulbs finish it off nicely.
Michael, your SVX looks gorgeous! Just from the tail end of it... how many miles does it have? Wait... 138k really?
1994 subaru svx le 112k Last edited by Subix; 03-14-2010 at 01:29 PM. Reason: e |
Thread Tools | |
Display Modes | |
