Old 06-06-2009, 06:50 PM
Not Not is offline
Need a part of radiator
Hello,
I got new radiator, but with crack on bottom plastic .
Maybe, anyone has bottom plastic part of radiator?
Thank you.
Old 06-06-2009, 06:56 PM
Re: Need a part of radiator
The end tank of the rad has a crack? If so you have to replace the whole thing, the plastic parts can't be replaced separately.
Old 06-07-2009, 07:28 AM
immortal_suby's Avatar
Thread Killah
You can repair it short term with some JB weld or magnum steel putty. But it won't last very long. I had one last about a year like this. The plastic is weakened when it cracks and it will soon crack again.
Locker Link
2015 BRZ Limited 6MT
Old 06-07-2009, 09:45 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
The plastic can be removed and reinstalled but trust me it isn't worth the trouble. Took me 5 or 6 hours to do it for an xt6.
Old 06-07-2009, 06:07 PM
Not Not is offline
Sorry for my english, what is "end tank of the rad"?
Photo of the crack in attach1.
I want replace ALL plastic part on bottom (attach2).
Alcyone SVX, E-CXD, vine, 1992
Old 06-07-2009, 06:11 PM
Not Not is offline
Yes, I tryed it. But after one month (in cold weather) anteefreeze has gone
In warm weather a little longer..
Old 06-07-2009, 06:14 PM
Not Not is offline
I know it! But, you know, russian "Levsha" may do it without big problems
Old 06-07-2009, 06:16 PM
Not Not is offline
"All I need is L..", I mean, that f.cking plastic part.
Dont want buy another new radiator!
Old 06-07-2009, 06:28 PM
benebob's Avatar
Not,
You're much better off with a new radiator as for someone to be willing to ship you a used bad radiator with a good plastic bottom will surely cost you mostly in shipping. It takes a good 2 hours to remove the plastic on a side mounted rad like the XT6 probably 3-4 hours on an SVX which of course is on the bottom and also longer. That's asking a heck of a lot for someone to attempt and there aren't any promises they won't damage it removing it. If you already have sourced one locally they I'd say it might be worth the trouble but if not I really don't think you'll make out and you won't be happy with the results long term. If buying a new Subaru one is too pricy there are other aftermarket options.
Old 06-08-2009, 03:47 PM
Not Not is offline
Not,
I see, thank you..
Old 06-08-2009, 03:56 PM
benebob's Avatar
Originally Posted by Not View Post
I see, thank you..
Don't give up on the jb weld idea though if it is cracked you have nothing to loose. Take a drill to the endes of the crack with say a 1/8" drill bit to keep it from cracking more, scuff it up REALLY good then clean it up really good, better yet to widen the crack a bit to get jb in there. Or just buy a used one from someone here and then you have yours for parts!
Old 06-11-2009, 02:42 AM
Not Not is offline
OK, I'll try, thanks a lot!
Old 06-11-2009, 03:17 AM
Not you have three options:
- Fix yours as benebob told you.
- Buy a used one from the network.
- Buy a new one off ebay.
I do not recommend you get a used plastic part and try to fix yours with it, unless it is new. A used plastic part might be "dried" and is prone to cracking.
