Old 03-30-2009, 06:48 PM
stuartracing stuartracing is offline
Re: fans not working
Just replaced my $3.00 el cheapo t/stat, with a Subaru $27.00 one and everything is working now, fans all kick on when they are supposed too...
Have ya checked that out yet????Cheap check...
Old 03-31-2009, 07:34 AM
Famouspork Famouspork is offline
Originally Posted by kwren View Post
and the MFI control module?
please educate me
Old 03-31-2009, 09:58 AM
What is the pressure and temperature rating on it? Because the prev. owner installed an 2008 outback rad on my svx. Might be different.
Old 03-31-2009, 10:03 AM
T-stat is on the front of the motor(behind timing covers and crank pulley) and replacing the radiator won't have an effect on what temp the thermostat opens up.
Old 03-31-2009, 10:51 AM
kwren's Avatar
kwren kwren is offline
controling the presure basicly is a function of the radiator cap. The 2008 outback rad has nothing to do with the fan motors not coming on.
If your thermostat is sticking, getting stuck in traffic wouldn't cause that to happen. If your themostat is sticking, it would make the temperature rise driving at any speed any where.
I would first test the fan motors to see if they are good. (easiest place to start) Next, if the fan motors are good, I would test the electrical circuit to see why they don't come on when they should.
If you don't know how to test the fan motors and do the electrical testing, just ask. Is a waste of time to keep grasping at straws. Testing is how you determine what you really need!!!!!!!!
There must be someone on this form that will be able to walk you through the process... (hint-hint)
Keith
Old 03-31-2009, 11:18 AM
Keith
well well!
Please go ahead, I'm all ears!thanks
Old 03-31-2009, 08:35 PM
kwren's Avatar
well well!
I have the easiest way worked out and will validate it to make sure by doing the test on mine tomorrow and let you know. Then you will be ready to go! Don't want to mislead you. It has to be done safely.
Keith
Old 04-01-2009, 11:40 AM
Keith
cool thanks!
Old 04-02-2009, 06:17 AM
I called carquest, and they said there was only one cooling fan relay, and it costs 250$ cdn, WTF?I saw 4 relays under my hood that must be worth 5 bucks each!
Old 04-02-2009, 06:31 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Pages 6-8 may be some help......
http://www.seccs.org/tech/manuals/19...OLING_FANS.pdf
Old 04-02-2009, 06:39 AM
This community kicks ass.Thanks guys.
Old 04-03-2009, 01:58 PM
Hey all!
The shop I went to just connected power to the fusebox and relays for the fans, and they are now working fine.
I am happy.Weehhee!
Old 04-03-2009, 11:15 PM
kwren's Avatar
We usually refer to that as "replacing a fuse"
Glad you got it done!
Keith
Old 04-06-2009, 12:43 AM
Hey all!
I am happy.Weehhee!
In doing so they have bridged out a very sophisticated control system for two fans working in tandem, linked to radiator water temperature, air conditioning, heater system, vehicle speed sensor and the engine computer.
Your engine will not run as efficiently and you may find a charge for the worse in MPG figures. You are lucky summer is on the way. In cold times you would be much more worse off. Meantime see if you can find someone who knows what they are about. They will need a wiring diagram for sure
Old 04-06-2009, 08:13 AM
they actually took 12v power from the radio circuit and powered the fan system with it.
Actually, it is running perfectly fine since friday.
