Old 03-23-2009, 02:53 PM
techy101's Avatar
techy101 techy101 is offline
A.L.I.C.E.
Send a message via AIM to techy101 Send a message via Yahoo to techy101
Question More problems...
I'm moving this from my progress thread into an actual technical thread. Sorry for creating so many, but I think this is where this problem belongs.
I got the motor put back in and fired up. She turns on and runs pretty well
BUT I am having a few problems.
To start, there is NO CEL or stored ECU code when I try and pull them.
When I first turned things on I got the 16 power light blinks. After some cursing I finally convinced the car to show me the code, and assuming I counted correctly it was a Trans code 22 which is listed as "Atmospheric Sensor." I have no clue wtf that is and I can't find it listed anywhere.
Also, the car seems to be in limp mode. I can't get it over 3k or it initiates a fuel cut (at least I think this is what's happening). I can hear a relay tripping from the area of the ECU each time.
Here's a video of said problem.
I'm wondering if this could have anything to do with my delete of the EGR system.
(I think I did this correctly) I plugged the exhaust port, plugged the port on the intake manifold, and jumped the two vacuum lines on top of each of the butterfly valves to each other. Then left all of the others alone.
For Clarity about what I did... Here are the remaining vacuum lines that I just left.
And here's the jump on top of the TB
Someone mentioned to me that it could be related to a crank or cam angle sensor. I just recently replaced the cam angle sensor, but there are still the two sensors above the crank sprocket.
For some reason my gut says this is related to the transmission error and not the motor so much, but I have no basis for that.
After I pulled the trans code the car quit giving me the 16 power light blinks, but was still acting funny. I pulled the battery and did the procedure to reset things, and then the blinking power light came back.
Also, basically every other time I try and start the car it doesn't want to start. It just cranks but doesn't catch. Much like when I don't have the ignitors plugged in. I pull the key out, put it back in and it fires up just fine
When we were putting the engine back in we jacked the transmission up about as high as it would go. Could this have damaged anything?
I think that's all of the information that I have right now. As usual, help is always appreciated.
ALICE: 2005 Forester XT (Ice Racing Machine)
River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment)
Old 03-23-2009, 07:52 PM
Re: More problems...
It does sound like crank/cam sensors. Can you locate some spares for testing?
Old 03-23-2009, 07:55 PM
techy101's Avatar
A.L.I.C.E.
I nabbed the two sensors above the crank sprocket from a junk yard car, but I have no clue if they work or not.
The cam sensor was just replaced recently so I doubt it'd be that. And that threw a code.
Any ideas about this mysterious trans code? I want to address the confirmed problem first before taking shots in the dark.
Old 03-23-2009, 08:20 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Less than 3k rpms is definitely "limp home" mode. Try resetting the ECU first (using the 2 blue leads in the driver's side kick panel). Next thing would be to swap out the MAF for one you know is good. Third would be checking the IACV and TPS to make sure they didn't get "dinged" during the overall process.
Good luck!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-23-2009, 08:28 PM
techy101's Avatar
A.L.I.C.E.
Good luck!
-Bill
I have already tried resetting the ECU by both using the 2 blue leads in the first 2 pins to clear codes, and by pulling the neg battery cable, turning on lights, hitting brake.
The MAF was perfectly fine before I pulled the motor and it was just sitting on the counter since then. I do have another one that I will try swapping in to check.
What is the IACV?
Also, again, what about this Trans code? It's a known error right now, and can't be just looked over.
Old 03-24-2009, 09:24 AM
SVXRide's Avatar
Okay, I watched your video and I "think" part of the problem may be that you're not supposed to actually start the car when you're checking for codes (yes, I counted the same 16 flashes as you did!).
Directions for checking the Codes
1) Remove the kick panel just beside the left foot rest on the driver's side.
2) Locate blue wires.
3) Locate black connector. Hold it notch up.
4) With ignition off, insert one of the wires into top row, 2nd pin from left.
5) Turn key to on position, but do not start the car.
6) Watch blinky check engine light on dashboard. Count blinks. Long blinks = 10, Short blinks = 1.
7) Keep watching blinky light until you get mesmorized.
To clear codes (after problem has been resolved):
1) With engine off, stick the blue wires to 1st and 2nd pin in the top row counting from left on the
black connector, with notch facing up.
2) Start car. Shut off car. Remove pins.
3) Read codes to make sure they are clear. No codes = steady blinks at 1/4 second intervals.
CODE PROBABLE CAUSE
11 Crank Angle Sensor or Circuit
12 Starter Switch or Circuit
13 Cam Position Sensor or Circuit (TDC Sensor on Justy)
14 Fuel Injector No. 1 (Legacy, Impreza, Justy, SVX)
14 Fuel Injector No. 1 and 2 (XT, Loyale, GL, DL)
15 Fuel Injector No. 2 (Legacy, Impreza, Justy, SVX)
15 Fuel Injector No. 3 and 4 (Loyale, GL, DL)
15 Fuel Injector No. 5 and 6 (XT-6)
16 Fuel Injector No. 3 (Legacy, Impreza, Justy, SVX)
16 Fuel Injector No. 3 and 4 (XT)
17 Fuel Injector No. 4 (Legacy, Impreza, SVX)
17 Fuel injector No. 1 and 2 (XT-6)
18 Fuel Injector No. 5 (SVX)
19 Fuel Injector No. 6 (SVX)
21 Coolant Temperature Sensor or Circuit
22 Knock Sensor or Circuit (Right Side on SVX)
23 Air Flow Meter or Circuit (Exc. Justy)
23 Pressure Sensor (Justy)
24 Air Control Valve or Circuit (Exc. Justy)
24 Idle Speed Control Solenoid Valve (Justy)
25 Fuel injector No. 3 and 4 (XT-6)
26 Air Temperature Sensor (Justy)
28 Knock Sensor No. 2 (SVX, Left Side)
29 Crank Angle Sensor (SVX, No. 2)
31 Throttle Position Sensor or Circuit
32 Oxygen Sensor or Circuit (No. 1, Right Side, On SVX)
33 Vehicle Speed Sensor (VSS) or Circuit
34 EGR Solenoid or Circuit
35 Purge Control Solenoid or Circuit
36 Air Suction Solenoid Valve (Impreza)
36 Ignitor Circuit (Justy)
37 Oxygen Sensor (No. 2, Left Side, On SVX)
38 Engine Torque Control (SVX)
41 Air/Fuel Adaptive Control
42 Idle Switch or Circuit
43 Throttle Switch (Justy)
44 Wastegate Duty Solenoid (Turbo Models)
45 Pressure Sensor Duty Solenoid (Turbo Models)
45 Atmospheric Pressure Sensor or Circuit (Non- Turbo Models) 49 Airflow Sensor
The transmission (TCU) has an entirely different self diagnosis process that involves actually pressing the manual button and moving the shift lever around...
-Bill
p.s. IACV = Idle Air Control Valve -- under the TB
Old 03-24-2009, 10:51 AM
techy101's Avatar
A.L.I.C.E.
LOL, The video was just to show the limp mode. I know how to pull codes. There are no ECU codes, and the trans code pulled was 22 after the whole PITA shift lever, press manual nonsense. The 16 Power blinks are just to say that there is a stored code.
Thank you for the responses so far, any help is always appreciated!
Old 03-24-2009, 04:06 PM
techy101's Avatar
A.L.I.C.E.
Well after some more fighting to get the code out of the car, I have double checked that the trans code is in fact 22 "atmospheric sensor." (as listed by the SVX-IW)
Code 22 doesn't show up on my AllData subscription so that's kind of strange.
I have three good MAF's right now, and I cleaned/tried all 3 and the result was the same.
I tried unplugging the Cam angle sensor and the car would only start for a second then stall. Unplugging either of the crank angle sensors resulted in a complete failure to turn over. Both also were accompanied by the correct CEL.
How does one go about checking the IACV?
I'll be testing the TPS sometime in the next couple of days, when some free time shows up.
Thanks!
Old 03-24-2009, 09:06 PM
SVXRide's Avatar
Sorry, I just thought from your posts that you were inferring a trans code from a blinking ECU code
Okay, let's go back to fundamentals....
1. You're in "limp" mode, per the "I won't go over 3k rpms" situation,
2. 16 flashes of the Power light = transmission error code, go check for TCU codes
3. Limp mode only happens when the car thinks something serious has gone wrong, in this case it must think the trans is fubared (?)
Given that it wasn't doing this before you pulled the engine, I keep finding myself coming back to the electrical harness and the connectors that were disconnected/connected in the process - especially the ones that go back to the trans.
Did you know that there is an EGR solenoid valve under the intake (part # 14774AA271)? It does send a signal back to the ECU...
-Bill
Old 03-24-2009, 09:18 PM
SVXRide's Avatar
Okay, here's some other things to consider.....
http://forums.nasioc.com/forums/show...ighlight=P0129
Since we run a MAF and not a MAP, I'm not sure if the NASIOC thread applies here...Can one of our resident ECU experts chime in here and confirm whether or not our ECU has a barometric pressure gauge built into it?
-Bill
Old 03-24-2009, 09:56 PM
techy101's Avatar
A.L.I.C.E.
-Bill
It's funny that you should mention that....
I just found this information on AllDataDIY
FUNCTION
The self-diagnosis system is capable of detecting any trouble which has occurred in any of the following input and output signal systems.
* Vehicle speed sensor 1
* Vehicle speed sensor 2
* Throttle sensor
* Shift solenoid 1
* Shift solenoid 2
* Shift solenoid 3
* Duty solenoid B
* Duty solenoid C
* ATF temperature sensor
* Ignition pulse
* Duty solenoid A
* Atmospheric pressure sensor
The results of self-diagnosis are displayed by flashing power indicator lamp.
* Repeated flashing at 4 Hz Error such as battery trouble
* Repeated flashing at 2 Hz Normal
* Output of trouble code Check faulty portion
* Continued lighting of lamp Error in inhibitor switch, manual switch, idle switch, or wiring
OPERATION OF INDICATOR LAMP
If trouble occurs in any of the self-diagnosis items, the following display appears on the power indicator only once directly after starting the engine.
And then I ran across this:
So it does appear that this points to the barometric pressure sensor.
Old 03-24-2009, 10:27 PM
So I've consulted the SVX bible (service manuals) and found the following:
Transmission Error 22: "Detects a faulty atmospheric sensor built in to ECU (MPFI)"
I'm assuming by ECU they mean TCU.
There is no troubleshooting guide for TCU code in the service manual.
I would replug the 4 main harness plugs to the engine as well as the 2 for the transmission. Also replug all the connections to the TCU itself.
The ECU has an atmospheric sensor as well (code 45). The service manual solution for this code: "When trouble code 45 appears on display, replace ECU."
Old 03-25-2009, 10:26 PM
techy101's Avatar
A.L.I.C.E.
After digging through a whole bunch of diagrams I think I have figured out how the barometric pressure sensor in the ECU relates to the TCU.
According to the diagrams it sens a signal directly out and into the TCU. As far as I can tell, it doesn't really go anywhere besides right out of the ECU and back into the TCU. On the diagrams I've found it shows no other connectors located in between.
I picked up an ECU and TCU today from the junk yard. I figure I'll try the easy fix first, after I first re-check all of my connections.
Old 03-26-2009, 12:15 AM
kwren's Avatar
kwren kwren is offline
Odds are... This is going to end up being something that didn't make it back in place on reassembly.
We all can do things to cars that they can't do to themselves.
Just keep your thinking cap on and it will happen!
Keith
Old 03-26-2009, 12:52 AM
techy101's Avatar
A.L.I.C.E.
Ah hah, more new information...
I think something is up with the vehicle speed sensor. It's the first I've seen of it, but when I just started her up the speedo was bouncing around a bit. It would be fine for a while, then bounce up, then be fine, it is intermittent with no pattern.
So far tonight I have tried disconnecting and reconnecting everything on the engine harness and cleaning it. Also I have tried replacing the two relays just in front of the ECU, as well as trying another TCU and ECU. Problems still remain.
Also, intermittently I have gotten a CEL for the cam angle sensor. Sometimes I crank it four or five times and nothing, other times first crank and she fires right up.
This ECU code wasn't here when the problems started.
