Old 03-19-2009, 11:47 PM
AUSVX AUSVX is offline
Registered Loser
Rear Diff Bushings
Hey Everyone
I'm being told that my rear diff bushings are cracked.
Was just wondering whether the whole diff or crossmember needs to be removed to fix that up or whether it can be done another way??
Unfortunately, I need this to be fixed in order to pass for registration and the registration is on the 30th of March
Jordan.
Old 03-20-2009, 04:09 AM
Re: Rear Diff Bushings
You have to remove the diff to have room to remove the diff bushings.
Usually I use a sawzall and make wo cuts through the outer metal of the bushing, about an inch apart, and then the rest of the metal pries out easily.
Old 03-20-2009, 06:10 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
I didn't remove the diff when I did mine. I only pulled the muffler and did the dual-cut sawzall technique on each bushing.
It's nerve-wracking to say something different than any given Tom would around here!
Old 03-20-2009, 06:29 AM
Registered Loser
Thanks for the tip, is it worth replacing a few other bits and pieces while having all that apart, like upper stoppers and lower stoppers and just general bits and pieces??
Old 03-20-2009, 07:17 PM
I'd just do the 15 Minute Mod.
Old 03-20-2009, 07:20 PM
Rob, how can you cut strait in like that without hitting the diff?
Your tool must have a MUCH shorter stroke than mine!
By the way, I went CC shopping today after I saw this.
Teeheeheeheeheeheeheehee, snort!
Old 03-20-2009, 11:59 PM
Registered Loser
Yeah im gonna work out the 15 minute mod story as well.
Do you think this would explain my problem where when I press the gas from stand still I hear this noise, coming from under the car, it's like a fast cluck cluck cluck but only happens from stand still for a couple of seconds, sounds like it's coming from under the centre console.
No it's not CVs
No it's not transmission mounts, because they have just been changed.
No it's not heat shields but not 100% sure
There are no codes.
Thanks for all the responses so far I wanna come to the conclusion of this noise!! it's been doing it for 6 months and I haven't fixed it!!
Jordan
Old 03-21-2009, 12:12 AM
legacyau legacyau is offline
a friend with an auto liberty has exactly the same sound occuring with his car and mine is the same too,we seem to think its the centre bearing/mount on the tailshaft its really hard to replicate while not driving
cam
Old 03-21-2009, 04:05 AM
No it's not CVs
There are no codes.
Jordan
Remove the driveshaft (propshaft) and check out the U-joints.
Old 03-21-2009, 07:42 AM
Tuck's Avatar
Tuck Tuck is offline
And if you have a high frequency vibration as well definately check the driveshaft somewhat like you have a tire out of balance.
How would I know that??? Ask OT
Old age and treachery will beat youth and skill.
Old 03-23-2009, 12:24 AM
Registered Loser
I'm not sure if you guys use the same lingo but are the U joints like saddles?
If I'm driving at speeds like around 80m/h would I know if the driveshaft was out of balance??
Thanks, Jordan.
Old 03-24-2009, 01:44 AM
subbieatnz's Avatar
My SVX does the same thing the clunk cluunk clunk noise ...
I think i have a stuffed diff on my one. the seals had gone and leaked the fuild out. you could also smell diff oil badly round the back.
I went to change my diff today and i suddenly relised my rear diff bushings have gone too. like 1 has No rubber... and the other has a bit of rubber sitting in it.
so i have another item to fix.
yay
1989 Vortex 6 Maroon
1983 RX Silver Grey
