Re: Cranks but won't start
Under rear seat…
Fuel pump modulator Rear wiper relay Auto Shoulder Belt Control unit… If you have one Keith |
cool. thanks for all the info. The under-seat connector is 2 wires.
The 5 pin connector is at the top of the fuel tank, right underneath the cover in the trunk. Perhaps the 2 pin connector to the actual fuel pump is inside the tank? Either way, it's right on top of the fuel tank where the tubing comes out. If I want to hotwire the pump to test if it's still working, which 2 pins should I hook up to? Pin1 and Pin3 (yellow & blue)? I'll try to get some pictures whenever I work on it again. Which file shows where these fusible links are?
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
Just checked the file F_BASIC_TESTING...has an entire fuel system test. I'll try that as well.
I would be real careful hot wiring the fuel pump. Just splicing into a couple of wires could be a disaster.
If you disconnect the 2 wires to the fuel pump and fasten a 12 volt source to the pump itself, you should be fine, just to see if it runs. Isn't learning fun!! Hang in there, Keith |
All I had time for this weekend was the starter fluid test...it started! It's good to know I'm barking up the right tree. Hopefully tonight I can test the entire circuit and see where I'm losing power!
Problem is just pumping is not always good enough the injectors need like 90lb ( just a guess ) I had a weak pump in my 1991 Turbo and had gas but would not strart. Yes first see if it pumps at all.
My understanding was that the fuel pump didn't run at all
Keith |
Haven't tried running the pump mainly because i don't know what voltage to give it. I figure if I shoot it 12V for just a sec, i can at least hear it run or not run. But, ignoring that, my tests to this point show 0v @ the fuel pump when I turn the key to "on" or to "start" even though the relay is good. So, I need to figure out why there's no voltage getting there. That's what I hope to test for next. Then i can find out if the pump still works or not.
*deleted - relay is fine*
Testing ECU outputs. Next is modulator and resistor. Anybody know how to drop the upper trunk trim without breaking all the clips?
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me Last edited by SVX10; 03-11-2009 at 08:19 PM. |
I'm an idiot.
Battery. End of story.
lmao....good job finding the problem tho. hahahaha
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill |
now i'm lost. didn't you say that it cranked all day? even started with a spray... |
#28
I have been following this thread. I thought its going to be something major
Now do you mean your battery is not producing enough voltage to ECU or starter Anyway, congrats on finding your problem.
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
