Old 02-22-2009, 04:22 PM
doug maire doug maire is offline
keystoneaz
Flickering Warning Lamps
1996 SVX Lsi
The dash warning lamps (Steering, Battery, Stop Lamp, Brakes) start randomly flashing on and off occasionally. There is no problem with the alternator or battery. Car runs fine otherwise. Ocassionaly the ABS lamp will join in.
Old 02-22-2009, 04:47 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Flickering Warning Lamps
Voltage regulator maybe, or ignition switch...... the two culprits ive seen so far here for that.
Old 02-22-2009, 04:48 PM
Originally Posted by doug maire View Post
1996 SVX Lsi
Could be a weakening alternator or bad connections in the wiring. Try cleaning off all the contacts of any involved wires with the battery and alternator.
Old 02-22-2009, 06:28 PM
genzzel genzzel is offline
Will pass gas for $$
Check connection at starter of hot from battery
Old 02-22-2009, 06:31 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Oh and clean your battery post connections, and check the wiring between the batt and alternator. Easy stuff first!
