Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 06-09-2009, 11:12 PM
Sanosuke's Avatar
Sanosuke Sanosuke is offline
Found a lost SVX
Re: Wilwood BBK kit coming soon
This may not be the right place to ask but... what about STi brembos? I assume the mounting is different for all of these. Why, if, are STi brembos not an option?
Can you find out and post how much a full four wheel set up of any or all kinds would be? I assume more than my cars blue book value.
:..Miharu..:(1994) Laguna Blue SVX 170k. MODs: Beat to shjt.
:..Fey..:2005 World Rally Blue Impreza WRX 80k and rising. MODs: Lowering springs, 22mm sway bars. SS brake lines.
Old 06-10-2009, 04:25 PM
There are many posts on the Brembos. They don't work. The bolt holes match, but the SVX knuckle is different and would put the calipers further out than the STi, requiring a larger diameter rotor. The problem is that the calipers used on the STi are already at the max rotor size they can accommodate. If you ran a larger rotor then it would either grind against the top and bottom edge of the caliper, or the pad would have it's outside edge hanging in space.
Old 06-10-2009, 08:00 PM
the_paynter the_paynter is offline
Originally Posted by BoxerFanatic View Post
Does anybody know if the 22B-STI/late WRX Subaru-logo 4/2 piston setup will fit the SVX somehow? Just out of curiousity...
I would like to know this my self as I have a set of 4pots sitting on the bench at my parents house. Maybe Ill answer this question.
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 06-11-2009, 01:28 AM
subbieatnz's Avatar
does that include the newer V9 sti and upwards?
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 06-11-2009, 05:22 PM
V9 = '08+? Nothing to my knowledge has been tried with those, likely due to rarity of cheap and easily available parts.
Old 06-14-2009, 10:08 PM
Lockleaf Lockleaf is offline
Pretend Innovator
While it is true that using a larger rotor on the STI Brembos would leave a corner of the pad unused, that does not necessarily make it an option some people would not desire to use. Intelligent or not, effective or not, like it or not, people have been using 350Z rotors underneath their 300ZX calipers for a while now. It's the exact same concept. They use a fabricated spacer to move their calipers out farther from the hub and then use the larger Z33 rotors. It's not perfect, but I fail to see how that makes it not an option. Even if it's only for show, that is all some car builders are looking for.
5MT - Impreza style, short shifted, TiC/Kartboy/ES Poly stiffened.
Old 06-15-2009, 12:58 AM
Thanks for the info
Old 06-15-2009, 09:28 AM
sicksubie's Avatar
If you are going to spend the money why not do ti the correct way that gets you looks and performance? Doing a set of STi brembos is still going to be a good chunk of money.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 06-18-2009, 10:42 PM
Banned
+1 sacrificing safety for looks when I'm planning to add more power is just scary.... I'm not down at throwing money at a pair of calipers just so they say brembo, I'm good with having stock 2 n 1 pots that are painted and function correctly
Old 06-23-2009, 06:28 AM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
Why yes....yes they do....I'm still getting them for my Impreza anyways though. So yeah... I havent'really searched through this thread and I know your sig says to PM you but what kind of prices are we talking about for Wilwood set ups?
-Gaddis
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 06-23-2009, 06:33 AM
sicksubie's Avatar
its only three pages.... The prices are not hard to find lol....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 06-29-2009, 03:02 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Originally Posted by odepaj View Post
Could you get me a price for the Wilwood 4pots with 2-piece rotors?
Also, what size rotor will these calipers use?
Thanks!
Dustin
Any news here?
Dustin
-Dustin
