Old 09-16-2008, 07:19 PM
Francis Francis is offline
oh man...
the oil leak that i thought coming out of transmssion "between transmission\front differencial" is actually coming out of the diff. I AM SO ****IN STUPID !!! i did'nt check the diff oil , dont know why ....
so today i cleaned my maf,engine bay,interior...i told myself meh i'll see what it looks like ...THERE IS NO OIL ON THE DIPSTICK !!!....i am telling myself can't be. do it again omg the dipstick smells like garbage, i am running that car with no oil in the diff i didn't notice anything wrong from it . first move tomorrow get lubrifiant for differencial
its probably already too late , what oil to uses ?
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 09-16-2008, 07:24 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: oh man...
Well since your in the Cold place I would use 75W-90
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-16-2008, 07:29 PM
Re: oh man...
would be good for summer and winter ? +30 celcius to about -30 celcius ?
rest in pieces
Old 09-16-2008, 07:32 PM
Re: oh man...
According to the FSM it's good for-34C to +32C so yes its good.
Seth
Past subies:
Other toys:
Old 09-16-2008, 07:34 PM
Re: oh man...
thanks for the help....and i've just found why i couldn't find anything good about this...searching differencial ain't good...its differential D'Oh....
rest in pieces
Old 09-16-2008, 11:30 PM
Re: oh man...
i am wondering if i could take it as a chance of doing a 4.11 swap , why is it harder without changing transmission ? and what is exactly the difference between stock and 4.11 , i am mostly doing highway over here there isn't a lot of hill except for highway ramps or bridges.....that is why i wouldn't go for 4.44 because i read it was better for low speed . is it worth the price ?
rest in pieces
Old 09-17-2008, 04:43 AM
Re: oh man...
What colour is the leaking fluid? Transmission fluid is red and the differential is oil coloured. The reason I ask is that you could have 2 leaks. I just replaced the transmission seal on mine where it meets the front differential. Luckily I had it done under warranty before I had the ownership transferred to my name. I saved $$$$.
Old 09-18-2008, 02:01 PM
Re: oh man...
brownish....i could of detect it before....
rest in pieces
Old 09-19-2008, 01:09 AM
Hondasucks's Avatar
Subaru Technician
Re: oh man...
You might be okay, no oil on dipstick doesn't necessarily mean that there is no oil at all in the diff, just means the dipstick wasn't getting to it. Fill it to the proper level and check for noises and such, and keep an eye on it until you can get it fixed.
1986 VW Jetta
Old 09-19-2008, 05:52 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Re: oh man...
hopefully it's not too late if you don't drive it a lot with low oil.
if it's too late, after a while, you might start hearing some grinding noise...
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 09-19-2008, 10:17 AM
Re: oh man...
there was missing almost 1 liter , i have to get it fix soon because its leaking alot , i don't know where it is leaking from tho , i know that oil gets to the transmission oil pan while i drive
rest in pieces
Old 01-30-2009, 03:23 PM
Re: oh man...
ok...to give an heads up, this may be an hijacking of my own thread.
started a week or 2 ago. while i am drifting i can feel the steering wheel shaking, if i remember i can feel it in the seat too. after reading a few post from other members , i am going to the conclusion that maybe the front diff is leaving me.
even if i am going straight but making wheels spin it is shaking. i ain't going so fast "dont have winter tire" but i know that at slow speed it is veeeeery scary . kinda making me feel my wheels are loose
any opinion ?
where to look first ?
edit : thanks. for help
rest in pieces
Old 01-30-2009, 07:43 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: oh man...
any opinion ?
How long since your tires have been balanced? Front out of balance will shake the steering wheel, rears will shake the seat. As they wear their balance can be thrown off as much as 2 or 3 ounces..... quite enough to shake you around. Id try that before worrying about your diff. Mine was the same way... when i first bought it I drove it to irvine and back from costa mesa for like a month with basically non-existent nasty black diff fluid at the bottom before I drained and filled it (was horrified). Now its just fine.
Edit: Oops wait a minute, at low speed?? Your wheels have become oval and need a shlacking......
Old 01-31-2009, 06:28 AM
Re: oh man...
when crusing its alright, i didnt get over the 50 km\h. i dont know how it looks like at high speed , but i know when drifting around corners it ain't good at all.
since my wheels are filled with uhh...i don't remember the name in english . it aint conventionnal air. the air pressure is not supposed to change with the temperature. but thanks for heads up .
since it is the winter i am waiting this summer to put on new mags maybe this will fix the problem.
but for now i am still looking to what could be the problem to be prepared to eventual cash eating
rest in pieces
Old 01-31-2009, 10:27 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: oh man...
Probably Nitrogen......
Do you have a way of getting all 4 wheels off the ground at the same time? Or maybe just the front or back two? Then you can shake it back and forth, sounds like you may have some loose linkage, balljoints, etc.
