Old 08-27-2008, 07:54 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
How To Remove Fuel Pump???
I opened up the plastic ring on top and pulled out the cover with all the attachments, but I dont see any thing bolted inside the fuel tank.
Any advice?
Thanks
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 08-27-2008, 11:44 PM
Eh? The fuel pump isn't inside the gas tank? Can you be more specific about what exactly you opened up and pulled out?
Old 08-28-2008, 12:02 AM
pearlm30's Avatar
Re: How To Remove Fuel Pump???
I guess I should be more specfic.
I removed the cover plate to gain acess to the fuel pump. I saw a eletrical connector and 3 smaller hoses and 1 bigger hose attached to top of the gas tank with a black plastic ring, I then turn the ring counterclockwise with small hammer and a screw driver. Then I could remove the top attachment piece and gain acess to inside the gas tank.
And I have no idea what to do next??? I didnt see anything in the gas tank that I can unbolt?
Old 08-28-2008, 01:19 AM
The pump should be at the bottom. Follow the two pipes that should be sticking up.
Added a diagram. #2 is the pump.
Old 08-28-2008, 04:55 AM
Dessertrunner's Avatar
When you look in you will see a clip that holds both sides of the fuel pump and the hose to the other side. Remove the clip with pointy nose pliers then the pump will lift out.
Tony
Old 08-28-2008, 07:36 AM
pearlm30's Avatar
Thanks guys, will give it a try later.
