Old 08-18-2008, 07:49 PM
barnett 327 barnett 327 is offline
belts
Can someone direct me in how to replace the power steering serpentine belt on a 95 six?
Thanks
Old 08-18-2008, 07:55 PM
Re: belts
One of the easiest jobs to do...
unlock the idler pulley nut (if looking at the engine, its the pulley down and to the left), THEN turn the idler pulley adjuster screw (the long bolt is what creates the tension, cannot remember at the moment whether clockwise tightens or vice versa)...but that is pretty much it. I am sure others will chime in to clarify.
Old 08-18-2008, 08:34 PM
Re: belts
Check the How-To Documents to find out more.
Old 08-19-2008, 12:07 AM
kwren's Avatar
kwren kwren is offline
Re: belts
clockwise tightens belt tension on the long adjustment screw. Don't forget to tighten the belt idler pulley nut after everything is back together and adjusted properly.
Piece of cake
Old 12-18-2008, 07:12 PM
coco-puff coco-puff is offline
Re: belts
Piece of cake
what if the tensioner bolt thing doesnt work...my pulley's stuck.
Old 12-18-2008, 08:05 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: belts
Coco, you DID loosen the pulley nut itself first right?? If you dont, the pulley tensioner bolt wont move it at all. If you did then maybe its a little rusted... its ok to tap the tensioner bolt lightly with a hammer to free it.
Old 12-19-2008, 01:27 AM
kwren's Avatar
Re: belts
Piece of cake
of course it works if you loosen the idler pulley bolt 1st. loosening the idler lets the idler pulley slide up or down when the long bolt is turned and not loosening the idler pulley bolt keeps it from sliding up or down.
if you don't loosen the idler pulley bolt, you might strip the long bolt threads.
Old 12-19-2008, 01:29 AM
kwren's Avatar
Re: belts
I would also lubricate the long bolt. It acts like a gear puller and you know they can be ruined of not lubricated.
Old 12-19-2008, 06:48 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: belts
I remember the first time I tried to do this myself. I was in effing Pennsylvania and ended up calling OT and had him on the phone for over and hour. I'm sure he was ready to kill me..
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 12-19-2008, 07:26 AM
Re: belts
Bret,
Don't be silly.
I'm STILL ready to kill you...
JK
