Old 08-16-2008, 11:48 AM
sicksubie's Avatar
Car still wont start...
So I ran the CEL's this morning and got a #14 (#1 injector). I went around and disconnected all the injectors an then reconnected them and tried to start the car.... Nothing.... Ran the CEL's again and got a 24, 28, 37, and 11. Uhmmmmm, help????
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 08-16-2008, 11:50 AM
sicksubie's Avatar
Re: Car still wont start...
I know why I am getting #37 by the way but the others are messing me up...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-16-2008, 12:03 PM
sicksubie's Avatar
24 = Air Control Valve
28 = Knock Sensor #2
11 = Crank angle sensor
It seems odd to me that all 3 things woud just miraculously happen at the same time. Also I do not understand how simply unplugging and replugging in the #1 injector that it would stop throwing a code as all the injector slips were on properly.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-16-2008, 04:52 PM
Manarius's Avatar
Manarius Manarius is offline
I'd check the crank angle sensor. That would definitely mess up the starting process.
-Jason
-Obi Wan Kenobi
Old 08-16-2008, 05:35 PM
Wikedjuggalo's Avatar
Rebuilding
I'd second that will ruin the starting process.
Old 08-16-2008, 06:47 PM
sicksubie's Avatar
Is there a way to check it without simply plugging in another one to see if it makes the problem go away?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-16-2008, 08:16 PM
Manarius's Avatar
I'm sure if you stick a multimeter up to it, you'll know. However, I don't know the necessary readings that you're looking for. Someone like Trevor would know...
-Jason
-Obi Wan Kenobi
Old 08-17-2008, 02:51 AM
SVeXy96's Avatar
SVeXy96 SVeXy96 is offline
Sold my soul to Subaru
Don't you know bad things come in threes silly!?! My car hasn't broke down in over a year and a half now and all at once last week I blew a coolant hose, my starter died and both of my radiator fan motors died...so yeah it can happen! lol
Meow
Old 08-17-2008, 07:30 AM
legacyau legacyau is offline
Just cranking the engine for long enough will throw cam and crank sensor codes, check you have the necessary things like spark & fuel my vote is fuel try spraying some fuel in the manifold and see what happens, if it fires you're on the right track ,
cam
Old 09-01-2008, 02:58 PM
sicksubie's Avatar
disconnected a coil pack and hooked up a spark plug and tried cranking the motor and.... No spark. The SVX has 2 crank angle sensors though I believe, so how do I know which one to replace?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 09-01-2008, 03:58 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
A bad water temperature sensor can cause your car to throw other codes as well.
I'm assuming you unplugged your battery for a while as well?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 09-02-2008, 08:38 AM
Bobby, it would be the one on the oil pump. The connector should be at a 90* angle... The other one should have a 45* angle
Old 09-04-2008, 11:56 AM
sicksubie's Avatar
Swapped in the new sensor and the car is running... YT: vacuum= 16" and AFR= 14.8-15.6 at idle. Also,I am seeing 23" of vacuum under load...
P.S. I need the belt numbers for the 9psi pulley. I only wrote down the blower belt ##'s but not the other two.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 09-04-2008, 12:01 PM
16" is still low... Too low for that engine. Are your fans running or a/c on at idle??
Old 09-04-2008, 12:06 PM
sicksubie's Avatar
no fans or AC....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
