Old 08-10-2008, 02:36 PM
processengr's Avatar
Mounting a fan to transmission cooler mounted in fender
Hi all,
My 92 Silver has the transmission cooler installed as in the SVXWN How-to:
http://www.svxworldnetwork.org/html/index.html
Has anyone added a fan to theirs?
My options appear to be :
6" or 7.5" diameter push fan mounted in front of it, or a pull type mounted behind it...if the fan will fit...
Thoughts, comments appreciated...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-10-2008, 03:00 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
Re: Mounting a fan to transmission cooler mounted in fender
how big is your tranny cooler?
my first svx had two small tranny coolers..
and my second had a larger one..probably 3 times the size of one of the small ones in my first..
i thought that was good enough...
as long as the car is in motion ...cooling should occur, right?
it's kind of like the idea of a front mount intercooler...it's away from heatsoak but with it being in the front..the car in motion will cool the air ~
Old 08-11-2008, 04:17 PM
Hayden Transaver
Plate-type
Core: 7.75" x 11.00 x .750"
Overall 9.5" x 11.00 x .750"
Installation looks identical to how to.
Found nice fans here:
http://www.the-fan-man.com/shop/spal...d96db7404c4a35
Thinking of adding Perma-cool transmission filter at same time...maybe LED wired inside car to show operation, relay kit, etc.
I travel on gravel and other loose road surfaces, don't want to cut a hole in the liner
Cheers! Gordon
2018 Tesla M3 30k
Old 08-11-2008, 04:23 PM
Originally Posted by processengr View Post
Hayden Transaver
Plate-type
Problem with that is, even with a fan you are recirculating the hot air already trapped in the fender from the cooler. You would be better off with a large cooler between the rad and a/c condenser
Old 08-11-2008, 05:01 PM
Maybe I'll be relocating it then, when I install the transmission filter...is there any downside to the Perma-cool style filter?
Cheers! Gordon
2018 Tesla M3 30k
Old 08-12-2008, 08:27 AM
the perma cool filter are one way, just make sure you get your in and out lines correct, thats all.
Old 08-13-2008, 07:34 AM
dromano's Avatar
dromano dromano is offline
By the dimensions of your cooler I think it is a 30,000 GVW cooler. If you put it between the rad & a/c condensor as YT recommended, you will be fine. I have 2 coolers this size in that spot, I also by passed the rad cooler. When I first by passed the rad cooler I got a 20° drop. So far with 2 coolers the operating temp is 30° cooler than with a single cooler. I'm in the desert, this time of year it's 100°-115° every day, in Conn, you should be good to go with one cooler.
If you install a temperature gauge and sensor in the Perma Cool filter mount, the wires can go thru a soft rubber spot in the firewall that is about 1.5" in dia. The soft rubber seals the wires. Perma Cool has 2 versions of the filter mount, be sure to get the one you can install the temp sensor in.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 08-13-2008, 07:44 AM
dromano's Avatar
The only down side is the bolts from Perma Cool are lag bolts. If you use the largest filter that fits the filter mount you will be doing your tranny & fluid a very big favor. I had a fluid exchange done (synthetic atf) in 2001, 40,000+ miles ago, I have changed the spin on filter every 7,000 miles, the fluid is as bright pink as it was when installed, no smell of burning.
Old 08-14-2008, 07:48 PM
immortal_suby's Avatar
Thread Killah
perma cool #12511 comes with the fan.
unfortunately if you live in the salt belt you have to keep it clean in the winter or remove it. Salt will kill the fan motor yearly.
I ran it like this for a long time with no fenderliner.
Locker Link
2015 BRZ Limited 6MT
Old 08-14-2008, 10:06 PM
Nevin's Avatar
Nevin Nevin is offline
immortal_suby, is your fan a pusher or a puller? Sorry if you said before and I missed it.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 08-14-2008, 10:37 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
I think this is a pretty good set up specially when you are stuck in traffic or going slow where you cant get enough air going thru the cooler( I used B&M trany cooler mounted in front of ac condensor).
How did you wire the fan switch? Is the motor pretty much water proof? Whats the trany temp. are you getting with this set up?
Thanks
I ran it like this for a long time with no fenderliner.[/QUOTE]
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 08-15-2008, 02:06 AM
longassname's Avatar
Just some dude.
I have a plate and fin cooler in the drivers fender with a fan on it controlled by an in line thermostat installed in the line between the transmission output and the cooler. I have the fender liner installed--a hole cut in the angled part of the bottom for an inlet and a hole cut high in the top for an outlet. I posted pictures and part numbers somewhere but don't remember where.
This set up functions well in everyway. Comes to temp fine and then runs 176 degrees no matter what without soaking the radiator with the heat from the trans fluid.
Old 08-16-2008, 10:09 PM
Thread Killah
I don't remember if it pushed or pulled. It's currently on my dad's svx and 800 miles away. I had one on mine also but swapped it out for a bigger cooler without fan last year in the same spot. I had it wired to come on with the ignition IIRC. The motor didn't seem to have a problem with water, just salt.
I also have a BM 70255 in front of the condenser and the stock radiator cooler is bypassed.
In any event, even with 2 coolers and the fan running, a good hill or some aggresive stop and go traffic could still push the temp way up. The fan cooler at least got the temp to cool down some at a stop. Sounds like Mike's setup works better than mine did if his keeps the temp that low.
Locker Link
