Old 08-10-2008, 12:31 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Rotors - vented Vs solid
OK my Baby has sold rears, can I fit vented (are they interchangable).
Are there any advantages - vented being on the rear?
thanks
Steve in NZ
Old 08-10-2008, 01:08 PM
kwren's Avatar
kwren kwren is offline
Re: Rotors - vented Vs solid
thanks
Steve in NZ
I would say not.
The rear doesn't have a heating warping problem as a rule.
(My 2C worth)
Keith
Old 08-10-2008, 01:12 PM
You have solid rears? Isn't yours a JDM car? JDM's came with slotted rears, as I recall, so someone may have changed your to solid rotors at a previous brake job. USDM SVXii came with solid rear rotors, so when I tried to buy rotors and got slotted ones, I found out they didn't fit.
I would bet that if you buy a set of slotted rotors they will fit your car perfectly.
Old 08-10-2008, 03:10 PM
SURTEESS's Avatar
Cool Re: Rotors - vented Vs solid
Mine are solid - they have been from new - even though here in NZ & AUS we got the same running gear (gearbox / diffs / ratio splits etc) - I have checked with the Subaru guys here & found out that the local market in NZ spec'd solid rear rotors - hence the original question about whether vented would fit, I will ask Dayle at Motorsport warehouse if the USA vented / non-vented dimensions are.
thanks
Steve in NZ
Old 08-10-2008, 04:21 PM
Ah, cool. Take a look at your capiler mounting bracket, that was what I found to be the problem with running slotted in my car. My bracket will only permit the thinner, solid rotors. The JDM vented rotors are 18mm thick. I couldn't find the specs on the solid ones, but probably 14mm or so.
Old 08-10-2008, 05:02 PM
SURTEESS's Avatar
Yes they are thinner than 18mm - I suspect that you are right about the thickness...
Old 08-12-2008, 07:16 AM
SVX_MY_BABY's Avatar
I got new rotors from Applied Rotor Technologies (ART) Both rear & front were vented & slotted. No trouble with fit & have stood up well. I think they are the same as Nissan Pathfinder. They were no more than OEM rotors.
http://www.subaru-svx.net/photos/fil..._BABY/4371.jpg
http://www.subaru-svx.net/photos/fil..._BABY/4367.jpg
http://www.subaru-svx.net/photos/fil...BABY/4388.html
Old 08-13-2008, 12:34 PM
Maxo's Avatar
Maxo Maxo is offline
Looks like your fronts and rears are both slotted but only the fronts are vented...
I could be wrong but, unless you use a lot thiner pad, I doubt you could ever get a vented disk into the rear.
Old 08-13-2008, 12:42 PM
SURTEESS's Avatar
Yes that is what I have found out - measured a JDM version & compared it with the NZ spec'd one - no-go.
Thanks to everyone who sorted this one out for me ....
Old 08-13-2008, 12:50 PM
boipeba boipeba is offline
I have put both slotted/drilled on my 95 LSI both front and rear and have no problems. They are also vented as well. Put in ceramic kevlar pads front and rear with no problems. Also put in the PWR radiator and that fit perfectly. Body work being done as we speak.
Boi
Old 08-13-2008, 01:30 PM
SVeXy96's Avatar
SVeXy96 SVeXy96 is offline
Sold my soul to Subaru
I got drilled and slotted on the front and rear. They are great cause my rims are always clean since I get no brake dust build up! If you don't care about JDM vs USDM you can get them for a good price form NAPA you can also order form the motorsportwarehouse.com
Meow
Old 08-14-2008, 03:14 PM
You may have me there. It's been a while since they were installed. I'll check when I switch to my winter tires & report back.
Old 08-14-2008, 03:49 PM
dromano's Avatar
dromano dromano is offline
How many miles do you have on your ART rotors? I have 40,000+ on mine (front only). I just changed the pads, the rotors look super. I got 40,000+ miles out of Akebono ceramic pads.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 08-16-2008, 07:41 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I just switched to solid because mine were starting to show cracks around the cuts and holes. Plus you can't cut slotted rotors. I've only driven the solid rotors for a short while but they seem very good.
Old 08-17-2008, 12:49 PM
dromano's Avatar
Boi
slotted/drilled/vented Tell us about vented, not familiar with that one.
