FMIC or TMIC
well, i'm at a crossroad. need to figure out if I want to do a FMIC or a TMIC. The one in the pic is from a newer WRX, i just put it there for measurement reasons. FMIC, need a new bumper, TMIC need a hood or at least a scoop to cut in. Hmmm, decisions.........
Depends how big you want it. You wanna use the stock WRX IC might as well leave it on top. Piping a FMIC might prove to be a bit more challenge, but it seems that is the name of the game. You can buy a hood or bumper in exactly the fashion you'd need for either.
I'd rest the decision on how big of an IC you end up using.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
everyone with a wrx upgrdes to a fmic...the whole point to putting a wrx motor in an svx is to have an aftermarket, no?
go fmic, and try to open up the bumper a bit for more airflow. Mabey relocate the licence plate, cut out the mounting for it, and put a lower lip to to scoop more air int the lower portion
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
i've looked at the bumper alot and its just not gonna look good chopped up for the FMIC. i may just have to buy one that has the larger clear middle area.
FMIC is viewed better as it puts the intercooler in direct air. If you choice to do that, then get a "Euro" front bumper. http://svx-motorsport-accessories.st...svxeufrbu.html
If you go with the top mount (less air, not as effecient, cheaper plumbing) go with the hood scoop hood. http://svx-motorsport-accessories.st...t/svxfiho.html Hope that helps.
-Chris '94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc. |
The whole reason WRX guys upgrade to front mounts is to reduce the massive heat soak a top mount sees under driving conditions. The only reason you should stay with a top mount is if you either don't have the money for a front mount, or can't put a front mount in due to severe space restraints. As tight as an SVX is in the engine bay area, you can get a front mount in.
he can easily fit the FMIC in, that engine looks tiny compared to ours...
<<As tight as an SVX is in the engine bay area, you can get a front mount in. >>
yeah, plenty of room now. |
Holy hell yea....you've got enough room to do a full DTM laydown with ducting through the hood Yea, don't even waste your time with the top mount if you have enough funds for a front mount. I'm actually selling two stock Evo 9 front mount intercoolers over the net on the DSM forums. If you're interested, they're $120 each shipped. You can view an ad for them on the DSM tuners forums here: http://www.dsmtuners.com/classifieds...ct=68930&cat=7 |
I'd say don't bother with the typical FMIC location. Built a custom rad mount to move the rad as close to the engine as possible, and stick the intercooler in front of the rad, inside the engine bay.
the ac condenser would still be in the way though.....
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
Put it between the cooler and the rad. Or get rid of it. It just adds weight anyway.
would not doing this swap and using a stand alone be easy? I mean doing it as a track only car...
From this angle that TMIC looks almost worthless and youhave enough room it would be silly not to do front mount.
