Old 05-02-2007, 12:59 PM
kis86's Avatar
kis86 kis86 is offline
replacing something or another
Send a message via MSN to kis86
Lightbulb How to take off rear quarter panel
How do I go about taking off a rear quarter panel (pass)?? I found one, but am not sure how to disassemble...
Old 05-02-2007, 01:30 PM
Remove rear side glass, rear windshield, body cladding, fuel filler neck, trunk-lid, tail-lights, rear bumper, wheel well liner, get out a cut-off tool and start going at the seams. Once you have the old one off you get to weld the new one in, and then re-install everything.
That's the basic idea anyway.
Old 05-02-2007, 01:43 PM
kis86's Avatar
Hmm
Would this be easier and less expensive to do compared with having the following crease taken out? Here's a pic of the bad one:
Old 05-02-2007, 01:46 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
It's going to be much, much easier to just take the dent out. You can get to the back side of the dent by just taking out the cardboard/cloth liner.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-02-2007, 01:51 PM
kis86's Avatar
Good
Great! That sounds better. Thank you both
Old 05-02-2007, 03:03 PM
It's Just Eric's Avatar
Missing in action
Rear quarer panel.....HUUGE pain in the ass. You really need specialized tools and some professional experiance to get it right. Pulling that dent, and making a clean diy repair...Peice of cake
Hammer it out the best you can from inside the trunk. It seems to work best of you start at the edges of the dent and work your way around to the middle rather than taking a big ol hammer and whacking the center.
If the offending area is stilldented, or it is looking kindof crinkley after you push the dent out, sand the area down with 80 grit and apply a few tight layers of body filler. Im pretty sure I typed out a basic idea of what to do from there somewhere else...a search should bring it up
Edit: Looking at the way the quarter meets the bumper in the first picture, pulling that out might be rather hard. but, if you were planning on trying to hang a quarter anyway...it cant hurt to try pulling it first. Just to get a better idea of what your up against, mind posting a picture similar to this, except with the trunk open? Thanks.
R.I.P Cool Signature.
