Old 04-28-2007, 09:35 PM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Unhappy SVX Not Starting...
So I checked the codes and I got a code 15 for Fuel Injector No. 2. I am not sure which injector is considered #2? Anyone know?
Thanks for any help!
UPDATE: Car is working again. Just need to take care of fuel injector now.....
Marisa
Old 06-11-2007, 04:03 PM
Ever figure it out. Best way to test the injectors is unplug them one at a time while the engine is running and if the engine doesn't change it's tune then you've found the defective one.
Old 06-11-2007, 06:18 PM
cozykat's Avatar
Thanks for checking up on me
I went and had all the fuel injectors cleaned and the code went away. After talking with John (svxcess), I think it was coupling with a coil going bad and causing a cylinder misfire because my car still rumbles at high speeds. So my next plan of attack is to go to subaru and have them check which coil on their computer - I am mostly curious what their computer will read.
Thanks again!
~Marisa
Marisa
