Old 04-20-2007, 06:36 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
brakes not grabbing.
I changed the calipers on my black svx beacuse they were not grabbing and had always been like this. I used the calipers from my silver SVX that I know work because I was using them before I took them off my silver SVX, which I was driving not too long ago. I just finish bleeding the brakes but they still don't grab all the way, they will stop the car but very slowly. What are other posible causes? how can I narrow the problem down?
Thank you.
Old 04-20-2007, 07:34 PM
Thank you.
By "not grabbing" a term normally indicating sudden abnormal brake application, I presume not working adequately is meant.
The question is, relatively just by how much peddle pressure is required if this is in fact the issue. If it is the prime problem, you should investigate the brake booster.
Old 04-20-2007, 08:10 PM
cdvs cdvs is offline
Poor brakes
If you have to 'stand' on them to work, it could be the booster, or vacumn lines to it. But, the booster just makes it easier, not better.
If you push on the pedal and it slowly drifts to the floor, it's the master cylinder leaking internally.
If neither of these applies, it could be:
A pinched or otherwise blocked brake line.
Air in the lines. (even ones you didn't detach)
Caliper not sliding on bracket.
Good luck!
Old 04-20-2007, 08:22 PM
Originally Posted by cdvs
slinding
Old 04-20-2007, 08:47 PM
when I push on the brake peddle It requires alot of force for it to finally stop the car and the distance that the brake peddle travels to stop is not very much. What's the brake booster?
Old 04-20-2007, 09:00 PM
Originally Posted by NikFu S.
Fizwd it ull op!
Old 04-20-2007, 09:07 PM
Sounds like you are not getting line pressure, then again I don't know much about brakes. Considering what he said about leaking, that's probably backwards.
Fizwd it ull op!
It's all goof.
Old 04-20-2007, 09:15 PM
Booster
The booster is a device that saves up the vacumn produced by the engine and uses it to assist pushing on the brakes. The 'power' in 'power brakes'.
The way you describe it, it doesn't really sound like the booster, but it's hard to say, even if you're only one state away. More force would be needed, but otherwise, stopping would be the same.
Check the lines to make sure none are bashed.
You could always swap the master cylinder and booster, but...
I'd put my time into making sure all the lines are bled, in the correct order, including the ABS.
Old 04-20-2007, 09:46 PM
how do you bleed the ABS?
I used the following order to Bleed my brakes:
Right Rear
Left Front
Left Rear
Right Front
Old 04-20-2007, 10:19 PM
Bleed Order
Right Rear
Left Front
Left Rear
Right Front
According to the manual, there are a primary and secondary bleeders on the ABS. The one toward the front is the primary.
The order is:
Primary
Secondary
Front Right
Rear Left
Front Left
Rear Right.
Sounds like you skipped the ABS and did them backwards.
Old 04-21-2007, 08:10 AM
I had no idea about bleeding the ABS!
How do I actually bleed the ABS? is it just like bleeding the calipers?
Thanks for your time and help with this.
Do you think this is the reason for my faulty brakes?
Old 04-21-2007, 08:45 AM
Yes, just like the calipers.
You're welcome.
Not certain, your description is unusual, although your problem may not be. What I'm suggesting is to eliminate the potential causes by doing the least time consuming and costly things first. That's what I'd do.
Old 04-21-2007, 09:41 AM
One more question before i get started. Which ones are the ABS bleeders? Please be specific. Thank you once again.
Old 04-21-2007, 10:18 AM
ABS bleeders
The top is your master cylinder.
The bottom is the ABS. There are 2 rubber caps on the bleed valves.
Old 04-21-2007, 05:27 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
If the brake is hard but then softly hits bottom, then you have air in the line.
