Old 04-12-2007, 09:51 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
charcoal filter
would removing that black cylinder (charcoal filter i think it is) affect how the car runs at all??
[SIGPIC][/SIGPIC]
Old 04-12-2007, 11:26 PM
I don't know if it would affect how the car runs, but I think I would keep it. Do you need to remove it for some reason?
Old 04-13-2007, 07:56 AM
jman050's Avatar
Its a Classic!
well i removed it a while ago when i swapped engines because it was cracked and i just linked the hose from one side to the other. My engine has never been 100% quirk free and im going to be trying to resolve these issues after im home in a couple weeks and im trying to get a head start on what might and might not work.
[SIGPIC][/SIGPIC]
Old 04-13-2007, 08:38 AM
I would replace it. It does provide a function and should be there. They should be easy to find. Good luck.
Old 04-13-2007, 04:23 PM
The charcoal filter simply absorbs fuel vapor from the fuel tank, which would otherwise be discharged into the atmosphere. There is no way it could affect the running of the engine even if the system was completely blocked, as the tank filler cap incorporates an alternative air inlet.
Old 04-13-2007, 05:35 PM
cdvs cdvs is offline
Charcoal canister
It is original emissions equipment, which is required in most locations in the USA. In Massachusetts, it won't pass inspection, if they notice it's gone.
Old 04-17-2007, 12:24 AM
NiftySVX NiftySVX is offline
It may not cause a noticable change in driveability, but it is part of the emission control system and needs to be in place. There is no telling what it might do without it. Definatly just get a new one, if for no other reason than to just eliminate it from any diagnostic process.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 04-17-2007, 12:37 AM
What it does and does not do, is definite and specific. Provided the fuel cap is not faulty there can be no affect on the operation of the engine.
Old 04-17-2007, 07:48 AM
Tiamat-red's Avatar
Tiamat-red Tiamat-red is offline
Following the path of the beam
As far as I know it's just there to "hold onto" any "left over" gasoline vapors that would otherwise be vented into the air.
Also, as far as I know, your engine doesn't know, or care, if it's attached or not.
Meaning as far as any engine problems go, there or not, it's not the cause.
Just take a page from my former young and clueless Honda days, just leave it in there and paint it fire engine red.
That way it will not only pass emissions, but will add like 5-6 HP as well.
Matt!
92 Ebony LS-L "Jabberwerwok" Now includes 1 *free "Wheeeeeee" per ride!
83 Honda Magna v45 "Grendel"
*Free after mail in rebate
