Old 04-12-2007, 07:52 AM
jeradsvx jeradsvx is offline
Send a message via AIM to jeradsvx
drive line noise
I have had a problem for the past few months and after driving my car on the highway yesterday it is time to do something about it. Here it goes:
when i am driving at speeds i would say above 40mph, when i am pressing on the accelerator i have a loud humming noise that i can feel in the car, can feel like it is in the driveline, doesnt shake the car but can feel the hum in the car. I have done the following to try to narrow it down, two new tires in the front, new alternator, new power sterring pump, crank pulley was replaced a 6 months ago.
When i take my foot off the gas at say 45 mph the noise is gone but once i start to give it some gas the noise comes right back, the noise is barley noticable at all at 25 or 30 mph. I wouldnt think it is the front wheel bearings they were recently replaced and i have had front bearings go before and there is no way that is has ever sounded like that, but maybe i am wrong. I would appreciate anyones input on this.
I thank you all for your help
Jerad
Old 04-12-2007, 10:44 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I've got humming noise but I think it's my tires.....My tires have maybe 10,000 on them, but they are summer ones and they sound terrible.....My dealer told me awhile ago I could have a bearing going bad in the front, but the car drives fine and the wheel doesn't shake.
I'm curious too what the noise could be...mine and Jerad's.
1995 Subaru Svx L / AWD
Old 04-14-2007, 09:42 AM
if it is a noise under load, sounds like carrier bearing in one of the differentials.... This means that the ring/pinion are probobly worn out of spec too. So, best bet is to try and figure out if it is comming from the front diff or the rear... I suspect the front because it carries more load than the rear and is suspect to failure more often.
Old 04-14-2007, 12:18 PM
chitownsvx chitownsvx is offline
i had mine changed
My differential before I changed it i could feel the lil vibration and hear it also. I changed the rear differential and now it's gone
Check me out and tell me what you think.
And vote on my poll.
http://www.cardomain.com/ride/2148680
This is the day I got my svx, and took it for a test drive, while helicopters watched.
http://videos.streetfire.net/search/...6373e299d2.htm
Old 04-15-2007, 01:29 PM
i have a spare front diff that is good........how hard is it to change it out.......
thanks
Jerad
Old 04-15-2007, 03:52 PM
gotta drop the trans and take it apart... I would not recomend a novice do this unless they are fully ready to break something
Old 04-15-2007, 04:48 PM
shop did it
yeah I had the shop do mine, I know I didn't want to tackle it.
Old 04-17-2007, 12:20 AM
NiftySVX NiftySVX is offline
Changing the front differential is a huge pain. It requires special tools, an almost complete transaxle dissasembly, and to make things worse, the ring and pinion gears are out of production. They must be replaced as a set, but that doesn't really matter because they are discontinued. If the front diff went away, or you the backlash is out, it's time for a reman tranny from subaru. I've done this on my car, and, unless you can carry a 300 pound transmission out from under the car and have a really good understanding of transmissions and extensive special service tools, I would take it to the shop.
Good luck.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 04-17-2007, 08:06 AM
its not that bad.... it just difficult and its hard to be confident in your work the 1st time around
