Old 04-17-2007, 09:13 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Originally Posted by SA SVX
I can swap it to = or - using the dip switch, the book says lights will flash as soon as the signal is received, or when you operate the door locks. Thinking of putting the horn circuit on the locks so i have an audible.
Then you should have the dip switch in the + position and the brown wire should show momentary 12V when you hit a button and should stay 12V+ once the car has been running for 10 seconds. It will also light up the lights when you work the locks. It flashes once when you lock it and they flash twice when you unlock it and then they stay lit for 30 seconds. What do you mean by "putting the horn circuit on the locks"?
