Old 04-01-2007, 08:46 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Shift kit- power light-16 times?
I did a long search on this subject, but have not found a simple explanation on the fix. Is there a "how to" on fixing this Power light blinking?
Old 04-02-2007, 12:19 AM
Besides having your power light blink 16 times, what are you wanting to do or fix? Not sure what you want here.
Old 04-02-2007, 12:53 AM
Turn the shift intensity down.
I don't know. Mine has been blinking for a while now.
Old 04-02-2007, 03:20 AM
dannmarr's Avatar
I work for my SVX
I had no codes before I installed the shift kit. The car drives fine, but I don't want to see the blinking light on the dash during start ups.
Old 04-02-2007, 10:10 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Install a new resistor like I did. 1 watt 390 or 430 ohms
See my pictures in locker
1995 Subaru Svx L / AWD
Old 04-02-2007, 10:59 AM
It does that if you unplug the resistor behind the battery. I would clear the codes and it should stop blinking. If not, search it and there has been some discussion on what to do.
Old 04-02-2007, 04:58 PM
What was the exact reason for installing this gismo?
Old 04-02-2007, 05:54 PM
dannmarr's Avatar
I work for my SVX
Trevor,
I didn't spend every last penny on the car yet. but seriously, no more upgrades for me. I had a bad experience with the stage 1 chip, and now with the shift kit. This is the last amount of nonsense money I will spend on the car.
Old 04-02-2007, 09:57 PM
There was a problem with the flashing power light at one time, but I thought they got that fixed.
Old 04-02-2007, 10:47 PM
kwren's Avatar
kwren kwren is offline
flashing lite at startup?
"get over it"
Old 04-03-2007, 10:11 AM
msvx95's Avatar
It's just a phase
Originally Posted by kwren
"get over it"
huh?
Dan, you purchased the shift kit...you might as well get good use out of it..I'm sure it works...how are your shifts? Smooth, jerky?
The blinking light can be fixed following Trevor's expertise and it does work as I have done so with removing the standard Small car resistor and soldering the lower ohmed resistor.
Anyone,
Has Small Car made any changes to the kit to reflect the lower resistance??
Old 04-03-2007, 10:19 AM
"get over it"
That was helpful. I would want to get it fixed so it was right so I would know if there were other problems if it was flashing.
I thought Small Car had made some changes to take car of that, but maybe not. It would not surprise me at all. There has been discussion on how to fix the problem in the past. Good luck with it.
Old 06-07-2007, 09:01 AM
It's been determined that the smallcar shift kit may not be assembled correctly. There is another thread explaining what had to be done to get it to work properly.
Old 06-07-2007, 09:33 AM
Kelvin Kelvin is offline
Banned
Trevor,
What was wrong with the ecutune chip? Please share, I'm thinking about buying one.
