Old 12-04-2006, 03:56 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Gas gauge not working
Has anyone ever fixed this problem? Can it be fixed?
Old 12-04-2006, 04:16 PM
Manarius's Avatar
Manarius Manarius is offline
On the Legacy's it's usually a problem with the contacts on the sender to the fuel gauge being corroded. Probably the same with the SVX.
-Jason
-Obi Wan Kenobi
Old 12-04-2006, 05:26 PM
Yes it can be fixed.
Please be more specific with some clues we can work on. Did the gauge fail after any specific incident. Are there any other electrical faults? Does the gauge pointer move or is it stationary and if so at absolute zero? Does it flicker?
Old 12-04-2006, 10:15 PM
dannmarr's Avatar
I work for my SVX
The gauge shows full only after a fill up. After about a few miles it goes to empty. I usually calculate my miles or just wait untill the low fuel light goes on before filling up. I could live with it, but it's the last issue to resolve on my car. Thanks for any help.
Old 12-04-2006, 11:51 PM
It would be logical to suspect the sensor unit located in the fuel tank.
When the tank is full the unit will register between one and three ohms across the signal line. When empty, 54 - 56 ohms.
Does your empty warning light come on if the tank is very low? This level is sensed separately by means of a thermistor.
Old 12-05-2006, 06:51 AM
dannmarr's Avatar
I work for my SVX
The warning light does come on. Is there a "how to" on this fix? How do I get to the gas tank to replace this part?
Old 12-05-2006, 02:42 PM
There are two fuel sensors, one in each tank. They are connected in series. If you can fix this problem that has plagued nearly all the SVXs, we will be eternally gratefully.
Old 12-05-2006, 02:49 PM
Lina Lina is offline
If it goes to empty after a few miles, wouldnt' that look like a sender with a leaky float?
Old 12-05-2006, 04:16 PM
The SVX has one saddle type tank. The two sensors required because of the nature and shape of the tank do increase the complexity. Each must be checked separately as suspect, but this is surely an easily understood contingency. However it is granted that there is twice the possibility of failure.
