Old 11-24-2006, 10:53 PM
crotchrocketony's Avatar
crotchrocketony crotchrocketony is offline
parking lights wont turn off
Go figure.... I got a new problem with my problem child! my parking lights wont turn off...but the weird part is when you turn the lights off the dash lights go off but the paking lights dont and they dont turn off when I turn the key off either.....so I had to pull the fuse so the batt wont die... any ideas
Tony
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs
Old 11-24-2006, 11:10 PM
Manarius's Avatar
Manarius Manarius is offline
Tony
Switch on top of the steering wheel. Turn it to the off position.
That is all.
-Jason
-Obi Wan Kenobi
Old 11-25-2006, 12:04 AM
ok im stupid. I let my girlfriend drive my car aned got it back with a dead battrie and with all the problems I have with this car (at least 1 new problem a week) I just figured it was a new problem. good, one issue off the list...butI still have to do a flexplate and a front diff (the guy who put the new trans in didnt put front diff fluid in it so on the way home it got the diff hot...so hot it melted the plastic gear for the speedo and I have some front diff wine. I guess you get what you pay for...$200 is costing me a hell of alot more! im guessing my flex plate is something from him to...Ill see once I pull the trans...good thing I have my old trans with a good front diff!
Old 11-26-2006, 12:21 PM
rallyingrob's Avatar
rallyingrob rallyingrob is offline
your parking light switch is on steering column?
i know most subeys have them on column but my 92 has a push button on dash to left of steering wheel lower down beside mirror heat button.....
i'm too svxy for my car
rob
92 ebony 4.44's rock !!
Old 11-27-2006, 09:37 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
all should have them in two places....on the blinker column where you turn the switch for your normal lights, and then one on top of the steering column...its a on/off switch.
1995 Subaru Svx L / AWD
Old 11-27-2006, 11:08 AM
dcarrb dcarrb is offline
This is correct; there is no switch atop the steering column; not in a '92, anyway. And the stalk- mounted switch operates the parking (or in this case,"running") lights only when the engine is running, as with the headlights. The dash-mounted switch allows parking light usage without the ignition key.
dcb
Old 11-27-2006, 11:18 AM
dcb
Yeah, that's true.
My Legacy used to have the switch on top of the column. The main problem I had with it, it did not light up, or there was no way of knowing it was on as you left the car [the clocks would be dark]. So in theory, if you were not careful, or in a hurry, you could lock up and leave the car with the park lights on. All night. Or whatever.
A surefire recipe for a flat battery, and I never liked it.
Old 11-28-2006, 05:08 AM
i was told it had something to do with the regulations in japan......
cars parked at road-side must display lights......
i guess so they dont get run-into............?!?!?
rob
Old 11-28-2006, 05:23 AM
The emergengy parking light is on top of th ecoulmn on all Subarus EXCEPT the SVX, where it is on the lower left side of the dash, by the Heated Mirrors button (if you have a LSL)
Old 11-28-2006, 10:52 AM
ok im stupid. I let my girlfriend drive my car ...
First rule with a SVX is: Never let anyone else drive your SVX.
Second rule is: If you are tempted to let someone else drive your SVX, see rule #1
The switch that was turned on allows you to have everything else turned off except the parking lights. That could come from a law in Japan.
