Old 11-12-2006, 05:43 AM
Speed related ticking noise
If I drive my car with stereo and all off I can hear a light ticking noise comming from drivers side I believe. The noise seems to be speed related when I speed up it ticks faster and as I slow down the ticking slows down until I stop the car then the noise stops. It is starting to drive me nuts and it will probably end up being as easy fix, but for now I just turn up the stereo. I do not believe it is comming from the engine. I have been under the car a dozen times even a few with it running trying to find anything that could be hitting or is out of place, but no such luck. I was thinking maybe drivers side axle is bad. Both fronts were replaced about 30,000 miles ago maybe I got a bad one. Anyone else have any ideas or maybe have had a similiar problem?
Old 11-12-2006, 07:14 AM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
yeah i had the same problem a while ago, sounds like card in bicycle spokes? Its nothing really.....
JUST YOUR FRONT DIFF. -Probably
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 11-12-2006, 03:42 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
It's probally your speedometer. Mine does this too, My solution: Louder exhaust. If you want to find out for sure then take the plastic lense off your gauges and take it for a drive and see if it's louder. This is what verified it for me. Good luck.
Old 11-13-2006, 02:37 AM
Yeah I've already done louder exhaust and full stereo setup. I just wanted to make sure it wasn't anything serious. As far as my front differental goes wouldn't I be getting metal fragments and such comming out when I change the fluid if it was on its way out. The fluid was changed about 5 months ago and I did it again today. The fluid looked very clean with no metal shards or fragments. I will have to try taking the lense of gauges and see if its louder. Is there an easy way to get the clear lense off? Thanks for the replies.
