Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 11-02-2006, 04:07 PM
dynomatt dynomatt is offline
The DBA catalogue that Danny posted is a wealth of disc information, there's just not an easy way to search it.
Are you saying the Brembo's were on the STi's before they changed to the 5x114.3 PCD? So in an 04 model or something?
Reading the DBA now,02-04's came with Brembo's, but had a 25mm thick disc. The 05-06's have a 30mm disc.
Hmmm...if your'e getting the early Brembo's, the SVX disc will be too small in diameter and too thick in thickness.
If you have the chance, the later ones would be better, because there's a much wider selection of 30mm disc rotors in that diameter...25mm thick is a bit thin.
Old 11-02-2006, 04:09 PM
I didn't catch that.. I believe the ones I am getting are from a JDM car so I need to look a little closer
Old 11-02-2006, 04:12 PM
http://www.dba.com.au/dba_catalogue_...gue_261006.pdf
Page 111 has the WRX stuff.
M
Old 11-02-2006, 06:41 PM
NeedForSpeed NeedForSpeed is offline
Looks like a misprint on the 02-04 sti.
The original thickness is listed at 25, minimum at 30? Matt, can you send an email and ask for corrected info? More info on the height of Tribeca rotors? What is the height of f/r svx rotors?
If the wrx two pots don't bolt up, does that mean that the rear Brembo won't bolt up?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 11-02-2006, 08:34 PM
Another interesting resource.
Brembo site
Seems you can search by dimension
I haven't tried for your situation yet.
Old 11-02-2006, 09:21 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
Originally Posted by dynomatt
I'm with you Tom...WRX 4 pots ARE bolt on, STi' Brembo's PROBABLY bolt on...they've got to be the path of least resistance.
Tom, are you saying WRX 4 pots (not Brembos) are $600USD a pair in the US?
Did I mention elsewhere that the WRX 2 piston rears DO NOT bolt on...
Tribeca is a good question...are they 5x100PCD or 5x114.3? Given they are virtually a Legacy platform (I think aren't they?) they would quite likely be 5x100.
M
WHOOOOOOOOOOOOOAAAAAAAAAAAAAAAaa
WRX 4-Pots DO indeed bolt up????? insane
Also- for $600-800 i could go for the light 4 piston fronts if it includes EVERYTHING, I mean: calipers, pads, the whole 9 yards
Hope all the wheels are moving in the right directions.......
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 11-03-2006, 12:01 AM
perfect Danny... I have been looking for something like that... It will help come next week
The SVX is mentioned in the Australian Catalogue:
Edited: Already posted by Matt
Old 11-03-2006, 05:11 AM
mikecg's Avatar
mikecg mikecg is offline
I'm going to try to get together with a few guy's from NASIOC this weekend in Delaware. There having an install meet. They said if theres time they'd let me steal a rotor and caliber from an STi for a test fit. Here's to the hope that I have the time to spare this weekend.
Old 11-03-2006, 02:45 PM
DOIT!!!
Old 11-04-2006, 05:53 AM
BAC5.2 BAC5.2 is offline
Not sure if it's been verified yet, but 04 Brembo's are 30mm wide, not 25.
Dia = 326mm, thick = 30mm, min thick = 28mm. The 04's have a 58mm hub.
I've got 3 04's and 2 05's sitting right in front of me that I looked on. All have the same width rotor.
Just thought I'd throw that out there to clear up confusion.
Old 11-04-2006, 07:26 AM
wawazat??'s Avatar
Yeah, I'm still around
WRX 4 pots are a bolt on but they require a different rotor as the "hat" height to use that caliper is different than ours. The Stoptech WRX kit caliper also bolts on using their brackets however it pushes the caliper out too far from the hub to use even their larger diameter two piece rotor (which is dual drilled, 5x100 and 5x114.3).
The Tribeca uses 5x115.3 BCP.
Todd
Down to none
Old 11-04-2006, 11:26 AM
When bolted on the svx, do the WRX 4-pots clear the factory aluminum wheel?
What 'hat height' is needed to use the 4 pot on the SVX?
Todd
Old 11-04-2006, 11:32 AM
The dba.com.au catalog lists the sti hat at 53mm?
Old 11-04-2006, 12:04 PM
mikecg's Avatar
I didnt have time to figure out anything definit, but I compared the bolt points and tried to but the STI caliber over our rotor. It looks possible with the STi rotor. I needed about a extra 1.4 inch to fit the Caliber past our rotor. The bolt holes do line up perfectly though. There was a rush to move the car around and the rotors were stock on both my car and the STi, so I wasnt able to try to fit everything up. But eye balling it it look like it could be done it little to know modds. The only thing I forgot to look at was if the stock dust shield on our car could be a problem. I'll keep a lookout for another chance to do a better fit test.
Old 11-04-2006, 04:29 PM
The dust shield will be a problem because it's made for a specific rotor diameter.
