Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 10-31-2006, 09:56 PM
dynomatt dynomatt is offline
Sure Harvey...for you, anything!!
You'll have it tonight.
Old 10-31-2006, 09:57 PM
Yeah, measurements of the disc needed would be great..You are saying that wrx Red 4pots bolt right onto our hub??
Old 10-31-2006, 09:59 PM
I'll take some photos tonight.
I don't have the red 4 pots, I've got the black one. My research tells me there's only one caliper in a 4 pot that Subaru's released before the Brembo's.
Do you have other info to suggest they might be different?
Old 10-31-2006, 10:05 PM
no but I keep forgetting that AUS models are different from USDM models... Do me a favor and take some pics so I can just look at it. then i can ask for specific measurements
Old 10-31-2006, 10:08 PM
Sure thing Tom...they'll be on here tonight.
Old 10-31-2006, 10:11 PM
awsome thanks Matt
Old 10-31-2006, 10:39 PM
How much would it cost to send the 300zx and the 4pots my way?? Maybe we could exchange some parts... Maybe a 6mt X-member and shift linkage all ready to go into the SVX??
Old 11-01-2006, 12:17 AM
I'm using the 300zx ones on my car.
The 4 pots here go for around $650AUD. What's that worth in your money? I reckon it might be cheaper to get them there...weren't they only $50USD or so? We get a bit ripped off over here.
Old 11-01-2006, 12:34 AM
So I've bolted them up and measured. Photos attached FWIW.
Based on my measurements, you'll need a disc of about 24mm thickness and 317mm diameter. With a height of about 58-60mm.
The SVX rotors are not big enough. They are too thick which means they won't work at all.
Scanning the DBA catalog, discs could be a problem. I suspect you might need to get custom ones made using the 2 piece setups you can get...that's big dollars.
Old 11-01-2006, 01:35 AM
NeedForSpeed NeedForSpeed is offline
Nice work!, too bad the wrx caliper doesn't seem to be a low budget option.
What do the turbo 300 calipers look like? Can you take a pic for us?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 11-01-2006, 01:47 AM
The AU wrx rotors are 24mm thick? Are the new 4-pot wrxes for sale in the US using rotors 24mm thick?
Old 11-01-2006, 02:25 AM
New Brembo WRX's seem to be 30mm (the 05-06) with the 114.3 PCD. These seem the most likely as with the Brembo calipers (being already 30mm thick) and the 114.3PCD, they should go close to bolting on.
Tom will tell...or time will tell.
Old 11-01-2006, 03:44 AM
Heres pictures of the calipers.
Sorry for the quality
Old 11-01-2006, 03:48 AM
Photos are **** aren't they...I'll wait till it's light and maybe try again if people want.
Not sure if I pointed out...Subaru calipers about 6.5kg each...Nissan calipers about 2.5kg. 14lbs to 5.5lbs each
Old 11-01-2006, 06:11 AM
Speedklix's Avatar
Locker Link Solution
Wow, looking at em side by side you would think it was the other way around.
So the 4pots bolt onto our hubs huh? Thats great. You could always have a rotor made
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
