Old 07-28-2006, 02:22 PM
cdigerlando cdigerlando is offline
Piston removal
How easy is piston removal? Anyone have procedures from the service manual? (I need to get one of these soon). I have heard that they can be removed by removing the C clips through a port in the block. Is this true? If so accessing the center pistion must be a B***.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 07-29-2006, 07:16 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
They must be installed with circlip pliars withe the crank installed into the block. Ive used a long needle nose pliars, but its not for the faint of heart.
phil
~Phil
Old 07-30-2006, 01:55 PM
svxsubaru1's Avatar
Iam having a hard time finding it but some one wrote a how 2 on piston removal.
92 Honda CBR 600
95 Miata
Old 07-31-2006, 07:56 AM
Removal
It seems like I have heard that you need some long thin C clip removers. Then remove the access plugs in the side of the engine. Then rotate the crank until the clips become visible. Remove the outer pistons first then the inner pistons? I believe there is a special tool to remove the pin. Then also there would be the actual removal of the piston. Maybe we can push it out from the pan?
Chuck D.
Old 07-31-2006, 09:58 AM
Phast SVX's Avatar
you have the procedure down correctly. There are access holes on either side of the block, remove inners then outers, pistons will fall out. I didnt use actual circlip pliars but it would have been much easier.
phil
~Phil
Old 07-31-2006, 10:23 AM
I'm not sure how relevent this is, but HERE (especially page 2-3) is a good write up, and photo's of a hand made pin removal tool that was done for an XT6.
Old 07-31-2006, 11:17 AM
Thanks for the link!
Chuck D.
Old 07-31-2006, 11:26 AM
svxsubaru1's Avatar
So to remove the center piston piston clip you just need some really long pliers?
92 Honda CBR 600
95 Miata
Old 07-31-2006, 02:39 PM
Question
In thinking about the procedure to remove the circlips. I can see how the outer circlips could be removed. But how to get to the other side? Do you have to reach through the pin itself to get to the clip?
Chuck D.
