Old 07-12-2006, 04:28 PM
Mr. Pockets's Avatar
Moderator
'Wobbly' steering resistance
I don't really know how else to describe it. When I'm driving my car at low speeds (under 35mph), and if I slowly rock the steering wheel back and forth, I feel a wobbly resistance in the wheel. The faster I go, the less I feel the wobble.
Bad ball joint? Strut mount?
My rotors are pretty badly warped, and I'll be replacing them next month finally...but I can't believe that's the cause.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-12-2006, 10:53 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
could that be rack and pinion??????
Old 07-13-2006, 11:16 AM
We should start with the easiest fix...when was the last time you checked the power steering o-ring?
Old 07-13-2006, 03:55 PM
Moderator
I replaced it myself about 5-6 years ago...which is admittedly about as long as the first one held out before it started making hte belts squeal.
2005 Outback
END OF LINE
Old 07-13-2006, 07:55 PM
It's Just Eric's Avatar
Missing in action
...TirePressure?
MyCVJointsAreBadAndIKindGetTheSameThing...ButThenA gainIMightHave
MoreStuffBrokeThanIThink
R.I.P Cool Signature.
Old 07-14-2006, 10:15 AM
Originally Posted by It's Just Eric
...TirePressure?
Until you get a keyboard you can use alt-32 on the keypad to add a space.
Old 07-14-2006, 06:55 PM
And yes, please do that.
Old 07-14-2006, 08:05 PM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Bushings on control arms and ball joints
My Mustang was doing the same thing and it turned out the bushings on the control arms were bad and also the ball joints were worn out. I replaced both and it drives like new. I know this is a really different car but I hope it helps.
Paul
1992 LSl (Black Mica)
1965 Mustang G.T. Fastback
1990 Mustang G.T. Convertible
1986 1/2 Nissan 4x4
2004 Vovlo XC70 (wife's)
Wonderful Wife
Wonderful Son
2 Cats
Incredibly blessed!
Old 07-16-2006, 06:36 AM
Moderator
Thanks - I figure I just need to start replacing stuff up thre until it stops.
2005 Outback
END OF LINE
Old 07-17-2006, 11:51 AM
We can't replace just the control arm bushings on the SVX....yet
