Old 06-23-2007, 10:43 AM
JIMSVX's Avatar
JIMSVX JIMSVX is offline
.... what a sweet ride !!
My problem is with the auto-up & auto-down function not working. The only schematics I've seen posted for the driver's switch assembly don't even start to reflect the circuitry that's really in there. I'm going to open the switch assembly up and reconnect it to the door wiring. Then I'll move the slide on the driver's switch without the button. If it works, then my problem is with the button's plastic leaver not moving the switch's slide far enough to hit the auto up/down contacts. If it still doesn't work, then I have to dig into the switch/relay circuit.
Does anyone have a schematic that shows the complete wiring of the driver's switch assembly, including the relays?
Thanks
- Jim
'02 Outback - Wife's car
'96 Legacy Wagon - Son's car
'95 Legacy Sedan - #5 Daughter's car
'93 Impreza Sedan - #4 Daughter's car
'92 Claret LS-L - My car ____________
TOTAL = 595,000 Subi miles
Old 09-12-2007, 01:25 PM
spinn360's Avatar
spinn360 spinn360 is offline
So has anyone figured this out yet?? my subaru has had the same passenger side not going down only up problem for sometime now and I've replaced the motor the switch and checked the wires I just read this thread so I'm going to try and check the main switches I hope thats it.
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
Old 09-12-2007, 02:14 PM
JIMSVX's Avatar
My problem was with the circuitry inside the Driver's switch, either a bad relay or some other component. I was never able to find the schematic for the internals of the Driver's switch. I finally bought another driver's switch at a junk yard and that solved my problem.
I did have a problem once with the passenger's window switch and ended up fixing it by swapping it with one of the rear switches (who sits in the back seat and needs to open the windows, anyway?) I had to swap the connectors (cut and splice) to do that. All the remote window switches get their power through the driver's switch. So the driver's switch can also be the problem when one of the other 3 windows doesn't work.
Good Luck!
- Jim
Old 09-12-2007, 02:24 PM
Guyver280z's Avatar
Guyver280z Guyver280z is offline
Send a message via MSN to Guyver280z
Well, I got myself a new drivers side control and it works great, but the passenger's side is still not working, it only goes up but it wont go down.... and I also noticed the side mirrors are not working too and the fuses are OK.... Im so tired of this
Old 09-12-2007, 02:25 PM
ridered777's Avatar
Finally HAS a 3rd pedal!!
You wouldn't happen to want to sell your half-working drivers switch panel, would you? Mine doesn't have a drivers switch AT ALL, so one that just doesn't do auto up/down is fine with me... I just don't want to pay $100 + shipping for a new one if I can get a cheaper one.
That is, if you didn't destroy yours taking it apart. Wish any of my local junkyards had SVX's...
-Craig
Old 09-12-2007, 02:28 PM
Guyver280z's Avatar
Mine worked fine, but one of the rear buttons was broken and its missing, but everything seems to work... but the auto up and down of course
You can have it for free, just let me find it
Old 09-13-2007, 03:00 PM
ridered777's Avatar
I was actually talking to the guy above you... you posted while I was typing mine, haha. My drivers window switch is broken, so one with more broken switches doesn't really interest me...
-Craig
Old 09-13-2007, 03:15 PM
JIMSVX's Avatar
I sent mine to another guy who didn't mind that the Auto Up/Down wasn't working. Sorry.
- Jim
Old 09-13-2007, 03:18 PM
ridered777's Avatar
Shucks!! Figures.
-Craig
Old 09-13-2007, 09:56 PM
spinn360's Avatar
XT6 Motor in my SVX!
So I took apart my driver side switch and I actually took it apart when I say that, but anyways I discovered that the metal part inside under the switch on that side was not touching the metal above inside the switch. Well its kinda hard to describe I made a little pic showing it from the side view. The first is how mine was the second is how it's supposed to be, and is now. It was just on the side that makes the window go down, there are two switches in each switch if that makes any sense. One to go up one to go down but when there is nothing being pressed they rest touching on the top part of the contact point. Mine was bent so it was not touching the bottom or the top at resting. I rebent it and cleaned it a little and now it works I can roll down my window and up. (on a side note I now have an XT6 motor in my svx and that thing kicks butt its faster then the SVX motor I screwed up during this whole proccess)
Old 09-23-2007, 10:11 PM
so it was the master switch...?
Wait, the xt6 window motor fits and is faster? That sounds like a cool mod.
blk 92' LSL w/ average mods
Old 10-02-2011, 07:50 PM
dromano's Avatar
dromano dromano is offline
Re: Power Window Problem
As strange as this sounds, it's probably the drivers side switch cluster. The relays for all of the windows are housed in the drivers switch panel. You may not have to buy a new switch though. Take it apart (there are several screws on the top part), and spray everything down really well with electrical contact cleaner. Let it dry, and put it back together. This may solve your problem, and will keep you from having to spend 76 bucks on a new switch.
Mike
My driver side window control for the passenger window will open the passenger window but, it will not close the passenger side window, I have to reach across and close the passenger window with the passenger window control. Is cleaning the driver side controls with electrical cleaner the best first fix? The passenger window has been slow to close for some time, now it will not close with the driver button. What to do?????
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 10-03-2011, 05:01 AM
dcarrb dcarrb is offline
It's a possible, short-term fix you might as well try, but you'll probably need to replace the master switch unit.
dcb
Old 10-03-2011, 05:53 AM
dromano's Avatar
dcb
Thanks dcb, not much lasts for ever, old SVX proverb
Old 10-18-2012, 07:12 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Well as most of you said, I have the same problem. Passenger widow goes up but not down I switched switches from rear and nothing. Then I tried rear passenger side and it's the opposite! It'll go down not up help plz
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
