Old 07-04-2006, 11:43 AM
Crysis Crysis is offline
AK Rowdy
Send a message via AIM to Crysis
Knock sensor
My check engine light keeps flashing on and off periodically for code "22...knock sensor on right side". I understand knock sensors allow cars to run on lower octane fuel, but other then that is it a big problem? Also, since it is flickering on and off does that mean it could be a faulty sensor?
Old 07-04-2006, 03:05 PM
If you want to test the sensor then swap the 2 knock sensors. If the problem follows the sensor you have your solution. If not you will need to look into why your engine is knocking.
Old 07-04-2006, 05:32 PM
AK Rowdy
could it just be knocking due to a bad tank of gas...it was 93 though
Old 07-04-2006, 05:52 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
the SVX's knock sensors will go bad over time -- usually mileage approaching 180k miles. Their casings will crack and the harness lead will get brittle and crack. By not replacing them, you're letting them tell the engine to pull back timing that, most likely, doesn't need to be pulled back - thus hurting engine performance.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-05-2006, 05:54 AM
AK Rowdy
Thanks.....got one more question Does the check engine light always come on for only a second if there is a problem?
Old 07-05-2006, 10:31 AM
It stays on as long as the problem is currently occurring.
Old 07-05-2006, 04:10 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
hummm i wonder if thats what my code is.... (to lazy to check it) mine will come on for a sec too.... i though i was seeing things the first few times because when i was turning and it was coved up... i saw it for a 1/10 of a sec and was like... wait did.... nooooo... it would stay on... that happend 3 times... yeah i would replace the knock sensor they go bad... i see them go bad usually around 100k in MN
- John
Old 07-05-2006, 07:19 PM
AK Rowdy
yeah..mine flickers on real quick. Well i am pushing 122k, so its probably time to replace. ;/
Old 07-07-2006, 01:49 PM
Nomad Nomad is offline
The car named NIGHTMARE
Send a message via MSN to Nomad
hummm..yeah , mines is 210 000 k , and a code for the left one appears...I've read the how to but...im not sure... is it like a bolt? I've seen pictures but , i just dont understand how to unbolt them as i want to do it by take off only the alternator but not the entire intake as im not mechanicaly inclined for now......i learn
Nightmare is the name of the car...
Old 07-07-2006, 02:34 PM
Without removing the intake it's best to have a 2nd person to help.
It can be done this way and this is the most common way to change the sensors.
The sensors are shaped like a mini-doughnut and the bolt goes through the center to hold it in place.
Old 07-07-2006, 03:34 PM
ok so, all we do is unscrew , take it off, check the wires , put in the new one and thats it? doesnt seems to hard... thanks
Old 07-07-2006, 03:40 PM
You would think that. I hope you have small hands!
Old 07-07-2006, 03:46 PM
yes for the hands but, i got a friend that works mechanical stuffs with me and he'S real skinny and small
Old 07-08-2006, 01:12 PM
AK Rowdy
is there a how-to on these knock sensors. I am new to working on cars and dont know where to even start. If anyone could give me a general idea of where there at and what they look like it would be greatly appreciated. Thanks
Old 07-09-2006, 09:40 AM
immortal_suby's Avatar
Thread Killah
here is the location o fthe knock sensors.
Locker Link
2015 BRZ Limited 6MT
