Old 06-26-2006, 11:52 AM
SubaSteevo's Avatar
No longer blue member
AC compressor replacement Q
I believe the bearing is starting to go in my compressor, so it will probably be replaced in the near future. Can it be replaced without draining the system and requiring a recharge?
-Steve
01' MSM Lexus IS300
Old 06-26-2006, 11:59 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
I don't think so. The only way you can do it is empty the system and recharge it when the new compressor is on. It would help to have a recovery system because then you could put the old stuff back in at least instead of buying new. Good luck.
Old 06-26-2006, 07:54 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
In HVAC we are able to pump down the refrigerant to one side of the system while replacing parts. I don't know if it's possible with auto A/C.
