Old 06-22-2006, 10:57 AM
rbalach rbalach is offline
Shifter wont budge from "P"
Started the car, pushed the brake pedal, pushed the main shifter button, but couldn't get it out of "P". I did not hear the solenoid clicking to release the shifter either. I had to use the shift lock release thingi (pain in the a$$ on 94 and up models) to shift out of park.
My brake lights work, so i guess its not an issue with the switch connected to the brake pedal.
Question is, where is the solenoid that releases the shifter ? I've read its under the center console, but anybody know where exactly it is and how i can get to it ?
Thanks
RB
Old 06-22-2006, 12:20 PM
You may want to consult:
http://svx-iw.com/
->SVXipedia
-->Interior
--->Console Shift Indicator Light Replacement
Info there on removing the center console.
Old 06-22-2006, 12:23 PM
There is a switch that connects to the shifter, I had to jump 2 or the wires on it to get the key to release when I did the 5-speed swap...might be the way to fix it...the description of those wires are in the write up in my sig...
Old 06-22-2006, 01:58 PM
nysvx10 nysvx10 is offline
I had the same shift lock problem and eventually got fed up with always having to use two hands to shift out of park so I bought a used shift lock module on Ebay for like 10 bucks and spent 15 minutes installing it...problem fixed permanently. It's located under the center console by the E-brake handle.
Caleb
Old 06-22-2006, 02:11 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Mine doesn't work all the time either. Sometimes it does, Sometimes it don't.
Old 06-22-2006, 02:39 PM
Rd96SVX's Avatar
Rd96SVX Rd96SVX is offline
antidisestablishmentarian
Send a message via AIM to Rd96SVX Send a message via MSN to Rd96SVX
mine also has "touchy" days when it doesn't want to move right away.. never seems to last for more than a few seconds though
-Alex
1996 Brilliant Red LSi "Allie"
+226k mi.
25,000 lb GVW Trans-Cooler
Wet-sanded "cleared" Headlights
Charcoal 22% Tint
Removed intake resonator
'95 Probe GT Wheels
'97 grille
"New Addition" 1992 Teal LS-L
+156k mi.
Status... Reconditioning
