Old 06-22-2006, 09:33 AM
shotgunslade's Avatar
OEM Wheels and Tires
Four 94 Silver wheels with 225/50-16 Pirelli P Zero Nero MS mounted, balanced, approximately 6000 miles on the tires. Plus spare unmounted P Zero Nero MS with approximately 12,000 miles. The lot for $400. Would prefer pick-up or NJ/PA/downstate NY delivery.
Old 06-22-2006, 10:02 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
This is actually a good deal people..... I have 4 on my car with the same tires...and 4 rims in my garage...stock..that I will get refinished and new tires put on them.
1995 Subaru Svx L / AWD
