Koni insert update
Classic Garage is expecting 50 car sets of Koni strut inserts to arrive at Koni NA in Kentucky on 6/16/06 and then be shipped to them the following week. A number of sets have already been earmarked at Classic. I figured I would alert the crew.
Todd
Down to none |
Todd,
Nice! Now, back to work on other things Koni-related (enjoy Chicago!) -Bill
yeah keep me posted on the "next" update about Koni products...
Tom |
OK, OK, I get the message
Working on them tonight...actually in about 10 minutes.
Down to none |
How much are the struts and how do they improve the ride?
Its an insert that has to be installed into the factory strut bodies. Requires some drilling and cutting of the factory strut bodies. The Koni inserts provide firmer damping. They can be used with stock springs, but are best suited with springs that are stiffer than stock. With a spring that suits your driving style, the Koni inserts can provide a more controlled ride. Firmer yet not harsh. I sell the Koni inserts for $610 + shipping.
Konis also have adjustable rebound damping. This gives you some degree of tunability for different uses (track vs. street). The fronts are very easy to adjust (just turn a knob), but the rears are a bit tricky (remove strut from car, remove damper from strut assembly, fully compress damper, and turn the shaft one way or the other depending if you want more or less damping).
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
Sorry to interupt...
Hi, sorry to jump in this thread, I didn't want to start a new one for a simple question.
My brake rotors are worn out and warped, and I need new pads. Reliable sites for performance rotors and pads? I was thinking e-bay for them. Would that be a good route, or just more horror stories. Thanks, and sorry again for jumping in |
Well I warned you, thanks for the link
mychailo: is that 610 per pair or per set of 4, installed in struts or uninstalled in struts? I really want the koni's but I know I am not mechanically skilled or equipped to cut into my struts to install em.
Installation is extra. This is just the struts & bolts.
and??? (drop me a PM) -Bill
mychailo,
do you still offer the whole strut setup still? how much all put together, ready to install? |
Thread Tools | |
Display Modes | |
