Old 06-06-2006, 03:56 PM
hayasa hayasa is offline
"crunching" sound from gas tank area
When the car is cold and I turn the key to the 'on' position without starting it up, I hear a crunching/grinding noise coming from the rear of the car. I was thinking it might be the fuel pump being clogged with something (likely recently dislodged by the increase of ethanol in gas nowadays). Not sure, but the car starts up and runs fine nonetheless. Just don't want to be stranded. Any other idea? How much for a new fuel pump? (part + labor)
--94 SVX LSi
Old 06-06-2006, 07:01 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
It has a saddle style tank. One side has an electric fuel pump, the other uses a jet jump to transfer fuel to the other side. The noise you hear is just air bubbles in the jet pump. Nothing to worry about.
Unless I'm wrong.
Old 06-07-2006, 08:03 AM
Interesting... I had just filled up the tank, too. I'll keep you posted if anything goes wrong. I've been hearing more and more in the news about clogged fuel pumps and filters from the gas/ethanol mix so I was a bit concerned.
Old 06-07-2006, 03:13 PM
If the noise has gone away after the tank was filled, you can be fairly sure Beav gave you the answer.
Old 06-07-2006, 03:59 PM
Beav's Avatar
Not as old as Randy
The SVX fuel pump is pretty reliable. I can't recall anyone saying they had replaced theirs and actually cure what they were trying to fix.
Old 06-11-2006, 12:04 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
--94 SVX LSi
Silly question, but is it on the drivers side rear ?
Are you sure you arent hearing your power antenna
making noise ? the mast trying to go up ?
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 06-13-2006, 03:01 PM
Don't think so. In any event, it *seems* to have gone away. I drive it everyday and whatever it was has either been chewed up by the pump and is now residing in the fuel filter, or was just bubbles. Sounded pretty scary at the time...
Old 06-13-2006, 08:13 PM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
I have the same crunching, bubbling sound after opening the fuel line. I spent a good bit of time fixing problems and went through all fuel injectors, did a pressure test, etc. After closing the fuel line and turning on the key I heard the fuel pump pushing air through the line and pressurizing the system.
Strange that you heard it without opening the line. Glad it's gone!
