#31
#32
Thank you. If you can get them in aquamarine that would be best
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#33
/subscribe
Keeping my eye on this.
#34
David,
any progress on this effort? -Bill
#35
Not really...there's just not enough interest. If you can get at least 25 people to commit to this project (min 50 piece order) then it would be a go.
#36
didn't happen to see the thread early enough, i'm in.
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
#37
One added to the list. Still need 18 more people to commit to this project.
#38
Just want to clarify: what does the bushing actually do? stiffer ride?
An explanation would boost sales. thanks |
#39
It gives us an option to which there currently is none. You currently can't get the bushings separately. Right now if one goes bad you must replace the entire control arm.
These will be pressed in to replace the worn bushings. They will be stiffer and will improve handling.
#40
lower arm bushings
Hi - been long time, but Doug, if you are still managing this, I'm definitely up for one set, potentially 2. There are now two Snoopy's in the family after a long absence...
Maria_is_a_Speednut |
#41
This groupbuy is still dependant on enough people to commit in order to make it worthwhile.
We would need at least 20 complete sets before anything gets put into motion.
#42
Mr. Earthworm,
For those not willing to go back to the first post in this thread... Current list of interest: 1. Earthworm 2. SVXRide (2 sets) 3. mohrds 4. mission 5. shotgunslade 6. DarknessofDeath
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$ |
#43
please add me to your list.....
.....please add me to the list for two orders. If you get enough people.
Thank you! |
#44
add me to the Control arm bushings list
Hi,
If still available I would like to be added to the lower control arm bushing list. I would like to replace both sides, so I would like a total of 4 if they are the same for front/back of the left and right sides. Thanks, Ken |
#45
FYI replacement control arm bushes are apparently available ex Subaru Japan...according to the local NZ agents.
Quoted Cost (in NZD=70 cents USD approx) $48.00 front each (USD 30.80) $55.00 rear each (USD 38.50)
Ian "The faster I go...the older I get" |
