Using non-SVX rear knuckles isn't an option. Converting to a worse-than-stock endlink setup isn't in the future.
How hard is it to grind cast iron a few mm's? |
Why? Cost. Why reinvent something if you don't have to? You can get a full set of STi take-offs for anywhere from $100-$300. You can't even buy koni inserts for that price, and you pretty much have to go new with koni's. Yes you can find a used koni setup, but firstly, it's not going to be nearly as cheap, and secondly they're few and far between. STi suspension comes off all the time, the abundance is there. If you end up damaging the struts or springs, it's quick, cheap, and easy to find a replacement.
As far as the two cars not being compatibler, what exactly is the difference? About 150 pounds or so, big deal. The spring rates are similar enough if you scale them accordingly. Besides, there's a huge aftermarket for Impreza stuff. If that stuff can be made to fit, then our aftermarket suspension just increased a lot. It seems like common sense to me that if a replacement part is available that will work okay, then there's no point in trying to design something from scratch. You're more than welcome to though. |
Not being in, or aware of your market, I did not appreciate the magnitude of the possible savings in cost and this point of view.
You can compare it to your own market. Find the price for used STi suspension on rexnet or something, and compare it to the price for Koni/GC or any of the hit and miss JDM coilovers.
Here Konis are like $600 or something, and GC springs are like $250 or so. Plus you still have to do a lot of work to get it to mount up. Compare that to an average $200-300 for take offs, and some work to get the rears to bolt up. I think you can see why some of us are more interested in this idea. |
Thread Tools | |
Display Modes | |
